Diesel Air Heater Options? - Defender Source
Old December 9th, 2010, 10:16 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Has anyone done the research on what diesel-fired supplemental air heaters will fit into the seatbox below the passenger seat? With the 200TDI things really don't warm up unless traveling at about 50kph or higher (at -10C) and supplemental heat will be needed for sure at anything lower than -10C. I also plan on doing winter expedition trips and having a heater that can run overnight to keep things warm would be a big plus, especially in the event of getting stuck somewhere frigid.
Ideally I'd like to find something 2nd hand and cheaper than the $1200 that most of them seem to go for new.
Old December 9th, 2010, 10:25 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
a Webasto or a Eberspacher will work just fine. Search Ebay you will find one. You might want to add a second battery if you plan to run it over night so you dont find yourself without enough cranking amps to fire up in the morning.
there are a lot of use options on ebay. My webasto thermo top is very good. I use it almost every morning in the winter...
Old December 9th, 2010, 10:26 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
zz`
I picked up a used Espar heater a few years back. I would have to root around in the barn a bit to tell you the model number. I have a hybrid RR/90 (more 90 than anything else) with the 200 Tdi. It's RHD with fuel tank under the driver and battery under the passenger. I haven't yet figured out where to put it, so I'm still driving around cold. I've thought about building a metal box under the cubby to raise it up ~6", but I'm not sold on that idea.
John Karlsson
Hope Valley, RI
Old December 10th, 2010, 08:35 AM
Wabasto air top 2000 is what you want. I'll add one down the road but for now, the Thermotop is all I need to keep me cozy as parking and supplemental heat. So far, my z model takes about 45min-1 HR to warm up my cabin from 15F to cozy each morning.
Mark Kellgren
KM4BOR
diesel, heater
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
Cold air output from heater RyanB16 Defender Technical Discussions 19 December 26th, 2008 09:47 AM
Heater core ?? & FYI D90user Defender Technical Discussions 4 October 14th, 2005 03:27 PM
Heater Air Scoops Davis For Sale - Parts 32 March 3rd, 2004 01:23 AM
