Did I strip my Transfer case drain plug? - Defender Source
Old March 28th, 2011, 04:40 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
So undergoing changing all my gear oil over to royal purple on saturday, and saved the transfercase for last. I had drained, cleaned, filled, and refitted the drain plug hand tight, and then got out the torque wrench set to 23 lb-ft. Tightening, went to first click, released, eased into it more gently, and it just kept turning. I couldn't imagine that I'd given it enough torque to strip it. My only thought is that because I didn't replace the copper crush washer that maybe that's as far in as it'll go?
It's still well above finger tight, but not 23 lb-ft, and the royal purple should allow me to see any leaking (which I don't yet...)
Thoughts? Help!?
Old March 28th, 2011, 04:45 PM
dchapman
Daniel Chapman
1999 D1
If it's not leaking don't worry about it.
Old March 29th, 2011, 03:29 AM
TS888's Avatar
TS888
Tony Sims
1984 110
If you did strip it you can fix it with a thread insert next time you change the oil.
I've never used a torque wrench on a drain plug of any kind in about 35 years of getting greasy. Just snug 'em up, and remember you have to take it out next time so if it's too tight you'll be cussing at yourself.
Tony
1984 110 "Smokey" (sold)
Old March 29th, 2011, 09:10 AM
Could you explain this procedure to me? Aren't you supposed to stop at the first click? I have never used a torque wrench on a drain plug either.
That said, when I first changed the oil on my tdi I noticed the drain plug was leaking. I went to tighten it and it just kept turning. I ended up fixing that as I was afraid it would vibrate out. Your t-box plug could do the same. If you don't want to waste the fancy gear oil, just make sure a good sized area around the plug and the oil drain pan are spotlessly clean. I used brake kleen to do mine when this happened to me.
Old March 29th, 2011, 09:29 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Hope it wasn't a 1/2" drive torque wrench that you used
Old March 29th, 2011, 09:30 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Is it possible for the plug to fall in the t-case? That would worry me more that out as the oil dripping will end up on the rear window and door. Easy to see!
Old March 29th, 2011, 10:30 AM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
Is there something I missed on the inherent nature of a torque wrench drive size that would change the delivered torque?
1000 lbs of feathers weighs the same as a 1000 lbs of lead right?
I used the torque wrench, because this was the only place in the owners manual where it noted a torque spec for a drain plug. I imagine some LR engineer didn't choose to mention it simply because he was getting paid by the word, but that these must be commonly over-tightened. I'm guessing that maybe it was one of the PO's or past mechanic that set me up for this.
Old March 29th, 2011, 02:29 PM
kevkon's Avatar
kevkon
kevin
The problem with using a 1/2" drive torque wrench is that it's very easy to go past the desired torque ( especially at such a low setting) and you essentially have a breaker bar. Generally for lower torque settings it's best to use a smaller torque wrench in the desired range. And as was already mentioned, there is generally no need to use one on a drain plug. Usually that torque setting is given so no one overtightens and strips the plug. In your case, as you said , you probably were the victim of a previous strip out. We have all been there.
Old March 29th, 2011, 02:41 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Isn't the drain plug tapered pipe threads? If so, it should tighten and stop, but if forced would expand the cover threads and keep going into the t-case.
Semper Fi!
Old March 30th, 2011, 01:04 AM
I think this has been covered
http://www.defendersource.com/forum/...ad.php?t=27973
Old March 30th, 2011, 08:36 AM
kevkon's Avatar
kevkon
kevin
Another Land Rover quirk, inappropriate plugs.
Old March 31st, 2011, 12:32 PM
kzack's Avatar
kzack
Keith Zack
none
Just an fyi, I tapped the hole to 1/2-20 as discussed in the referenced thread and is still holding tight with no leaks / seepage. Used a generic plug from a local auto parts store. Only been about half a year to this point.
Keith
Drive the Best - Drive a Hammond
drain, drain plug, transfer case, trip
Transfer Case Drain Plug Problem kzack Defender Technical Discussions 10 October 21st, 2010 08:14 AM
Drain Plug Diffs/Xfer Case Grover Defender Technical Discussions 7 November 11th, 2009 11:21 PM
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
