Did I blow up my diff?? - Defender Source
Old January 2nd, 2011, 09:45 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
I heard a slight groaning out of the rear of my truck yesterday on my way home. Sounded like a bearing going out to me. I limped home slowly, and as I turned in my gate heard a pop. Still able to drive I made it to my barn and pulled it in the shop. I jacked it up in the rear to see if I could spin the tires to see which bearing was going out. Put the transmission in neutral and went to spin the rear tire. I could not move it. I wiggled it back and forth a few times, and heard I little pop, followed by some rattling (sounded like it came from the rear diff). Then the tire would spin freely. Then I put the whole truck on jack stands, put it in gear, and got out to take a look. The front tires were spinning, and the rear drive shaft was spinning, but the back tires were still. Guessing its the diff, but looking for some insight.
If it is the diff it is good news bad news: bad news its broken, and going to cost a lot of money. Good news, great time to do new gears and lockers I have been thinking about.
What are your thoughts?
That is why it is called a short cut. If it was easy it would just be "the way."
Old January 2nd, 2011, 09:53 PM
CDNRover's Avatar
CDNRover
Jeff Labb
110 Ex-Mod FFR 200tdi
You had power to the rear wheel? Can it be a broken axle shaft? Or as I experienced, broken gear tooth that get stuck between the crown wheel and the pinion one... try to get the half shaft out first. If they're complete then try to rotate the drive shaft to see if everything is alright in there. I think that by this point taking the diff out ain't much work and might prevent from a total blown out.
Old January 2nd, 2011, 09:58 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
There is no power to either rear tire, so it would have had to break both axle shafts at the same time. Does that happen very often? I haven't started taking anything apart yet. I will have time tomorrow afternoon. When I turn the drive shaft it spins freely, but doesn't turn the wheels at all. I had to lock the CDL just to back it out of the shop. When it was unlocked the rear drive shaft was just spinning, and I wasn't moving.
Old January 3rd, 2011, 02:28 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Actually, if one of your axle shafts snapped, and the differential isn't lockable, all the power will go to the broken side as it has no load, and is the "path of least resistance". But I would imagine you would feel/see *something* on the other tire, especially if it's off the ground.
Old January 3rd, 2011, 09:03 AM
Put a pan under the diff and drain the oil. If it is ruined, you'll see chunks in the oil drain pan.
I bet that you broke an axle. Only thing to do is start pulling it all apart. Take the axles out first and you'll see whether you have to go deeper.
Old January 3rd, 2011, 09:14 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
You didn't break an axle with an open diff. I'd guess you lost the spider gears/cross pin. At least the rear diff is easier to pull. Excellent time to drop in a locker.
Old January 3rd, 2011, 09:31 AM
The Dro
Dro
1988 Ninety
I also bet it's the half-shafts.
Removing the rear is as easy as unbolting the lugs on each side. But since something broken it's good to remove the third as well.
Great time to upgrade to HD half-shafts and locker.
Old January 3rd, 2011, 11:05 AM
Used diffs are cheap. Pretty easy job to swap out the axles and third member too.
Old January 3rd, 2011, 11:22 AM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
On the shafts I just unbolt them and pull them out right?
Old January 3rd, 2011, 11:23 AM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
yes...
Old January 3rd, 2011, 11:27 AM
You might have to pull both if one is broken and use a long rod to knock the broken piece out of the carrier.
Based on your description, I would strongly believe it was the diff, not the axles though.
Old January 3rd, 2011, 02:32 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
Both axle shafts are perfect.
Old January 3rd, 2011, 03:05 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
now that the shafts are out, you can drain your diff, unbolt the driveshaft, the unbolt the diff and pull it
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old January 3rd, 2011, 03:11 PM
There will be chunks of metal it in. Make sure to clean out the axle casing really well.
Old January 3rd, 2011, 03:20 PM
rmuller
Ryan
Yeah, it helps if you have a good magnet you can run through the length or the tube too to pick up any stray metal.
Ryan
Current:
2001 Discovery II
2006 LR3 HSE7
Old January 3rd, 2011, 03:24 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
I got the diff out. The ring and pinion look fine, but everything else is trashed and was laying in the bottom of the housing. How much harder is the front to change?
Old January 3rd, 2011, 03:27 PM
Front is about three times the work to change -- at least.
Why do you ask? Are you planning on upgrading both to ARB/DL/TT and new gears?
Ron
PS told you it was the diff not the axle shafts.
Old January 3rd, 2011, 03:36 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
This thread reminds me of what happened to my Series III rear diff, started hearing a weird knocking that got progressively worse, opened the drain plug, out came chunks of the ring. Pulled the diff, gave it to a shop with new bearings, ring and pinion, put it back in and so far so good.
Robert Deniro
Old January 3rd, 2011, 03:38 PM
rmuller
Ryan
Martin - i've seen 3rd members going anywhere from free to $200 ... hopefully if you look around you can find one for $50 or so locally... slap it back in and you'll be back on the road... then worry about upgrading on your terms.
Ryan
Current:
2001 Discovery II
2006 LR3 HSE7
Old January 3rd, 2011, 03:41 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Front is a little bit longer to change. same theory but you need to unbolt the hub piece that bolts to the axle housing. I think they are like 12pt 13mm bolts and about 6 or 7 of them and they can be a pain in the ass unless you have one of those ratcheting wrenches.
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
QT Services Diff Guards and HD Engine Mounts JohnC The Vendors Loft 1 February 16th, 2006 09:53 PM
diff guards and discovery rubber floor mats ToaDisco For Sale - Parts 5 June 5th, 2005 10:54 PM
need front/rear diff for 1994 D90 rover_rich_d90 Wanted 4 March 14th, 2005 09:05 PM
