Did I blow up my diff?? - Page 2 - Defender Source
Old January 3rd, 2011, 03:43 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
Ordered GBR 4.14 thrust bolted with ARB's! Seems like the perfect time, been kicking it around for months. That is why I need to know about the front.
That is why it is called a short cut. If it was easy it would just be "the way."
Old January 3rd, 2011, 03:44 PM
Anything out of a late 1993 RRC-1995 RRC, Disco I will fit unless it is the rear with the 3 bolt rotoflex flange which would require swapping flanges.
------ Follow up post added January 3rd, 2011 03:46 PM ------
You can either pull them apart at the swivel ball to axle housing or start working your way in from the outside. Me, I would do them from the outside and replace the rotors, pads, calipers if necessary and repack the bearings.
Old January 3rd, 2011, 06:34 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
can anyone point me in the direction of a write up on the removal and install of the front diff?
Old January 3rd, 2011, 06:41 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
To remove the front diff you have to remove the brake calipers, drive flanges, hubs, stub axles, CVs and inner axles, front drive shaft and tie rod(one end). Then you can unbolt and remove the diff.
Old January 4th, 2011, 08:56 AM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
another question: about 2 minutes before I heard the diff blow the other day my speedometer quit. Is this a coincidence?
Old January 4th, 2011, 10:05 AM
Probably.
Old January 4th, 2011, 03:00 PM
Defender90_218's Avatar
Defender90_218
Trenton Smith
1997 D90
Good luck with your purchase, when mine arrived from GBR they had a loud whine to them, 2 months of driving didn't help so they came out and went back to Utah and it took months for them to agree they had messed up the first diff and finally build/ship a replacement. So a heads up, when you put them in they if they are making noises send them straight back, they should be silent and need no break in. btw nce you get everything running we should go to the Marble Falls off road park and test them out.
Old January 4th, 2011, 08:10 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
This is the second instance that I've heard of this in the last 6 months. Makes me wonder what's going on....
Old January 5th, 2011, 07:13 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
got the diff housing all cleaned out. used a big magnet to get all the metal pieces out. The question I have now is how much diff oil 80w 90 goes in the diff?
Old January 5th, 2011, 07:54 PM
Ur, enough to fill it? I don't think anyone actually measures how much they put in. Just pump until it blurbs out. Get a pump from the auto parts store so you aren't trying to (cringe) pour it out of a bottle...it just won't happen.
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
QT Services Diff Guards and HD Engine Mounts JohnC The Vendors Loft 1 February 16th, 2006 09:53 PM
diff guards and discovery rubber floor mats ToaDisco For Sale - Parts 5 June 5th, 2005 10:54 PM
need front/rear diff for 1994 D90 rover_rich_d90 Wanted 4 March 14th, 2005 09:05 PM
