Did 1995 SW D90s come with an electric fan? - Defender Source
Old February 28th, 2005, 05:21 PM
arbik
Arbi Karapetian
1995 D-90 SW #163/500
Hi All,
I just talked to the previous owner of my D90 (I'm the 3rd owner) this past weekend.
My D90 has a single electric fan in front of the radiator, and the regular belt driven one behind it.
I asked him if he had installed the electric fan, and he said..that was a design change that happened mid-year on the 95 models.
Is this true?
If so, something sounds fishy. My buddy has #451/500, and his doesn not have an electric fan. Mine is #163/500, and does. IF this was a mid-year "upgrade"...then technically, his should also have it, since mine was built before his, right?
-arbi
Old February 28th, 2005, 05:24 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
It's an A/C fan. Other truck prolly didn't have AC.
Doug W.
Old February 28th, 2005, 07:45 PM
yup, you can turn that fan on when you turn on the fan for the AC, I think it might provide some extra air flow..
I have seen the D-90 wgn's (95) without AC.
Old February 28th, 2005, 07:51 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
It's the condenser fan for the AC
Old February 28th, 2005, 08:47 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Also, the numbers (such as 163/500) are random numbers and not build order--they basically were the number from which they were off loaded from the freighter or removed from the import lot and were stamped state-side for marketing purposes.
Old February 28th, 2005, 09:31 PM
arbik
Arbi Karapetian
BINGO!!
Thanks guys!! You guys are a bunch of wizzards!
The other truck doesnt have AC!
So, maybe I can put a bypass switch, and just turn on the fan, when needed. That would be good for cooling, no?
So the AC fan comes on with the AC internal fan switch? or the AC condensor switch?
-arbi
Old February 28th, 2005, 09:54 PM
AC comes on with the switch that has the blue on it, condensor switch. the fans come on with the fan switch.
Old February 28th, 2005, 10:29 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
On my 94 if i turn the temp on the AC all the way to its hottest seting it kicks the fan on without turning on the compressor. I was running like that on trails last year when I was running hot.
Jimmy Buffett
Old March 1st, 2005, 01:27 AM
arbik
Arbi Karapetian
man..what a nice feature to have
Thanks guys, much appreciated as always.
-arbi
1995, 90, 95, d90, electric fan, fan
Electric Cooling Fan 97 info needed. WHITE RHINO Defender Technical Discussions 8 January 8th, 2012 02:11 PM
I'm making a custom fiberglass electric fan shroud for D90, anyone interesed? jaherring Defender Technical Discussions 1 November 22nd, 2005 01:06 PM
Twin Electric fan kit for V8 D90 kiphartzell Wanted 2 March 17th, 2005 01:06 PM
Electric Cooling Fan Brackets wea Wanted 0 December 8th, 2004 12:52 PM
