diameter/thread of sending units for gauge upgrade - Defender Source
Old September 29th, 2005, 02:55 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Does anyone know offhand what the diameter/tread size is on the sending units for
1) temperature
2) oil pressure
I'm going to upgrade my temp gauge with a VDO and add an oil pressure gauge & need to order sending units (http://www.egauges.com shows them all). If someone knows this offhand it will save the trouble of removing them to figure it out...
(sending units: http://www.egauges.com/vdo_send.asp?...5Bar_VDO&Cart=)
VDO also has a pretty cool fuel gauge in it's 'marine' line which has a low fuel warning idiot light built-in. It might be cool to swap that in & replace the existing unit - anyone know the ohm range on the sender in the D90?
Jason
Old September 29th, 2005, 03:57 PM
For the fuel sendor range http://www.defendersource.com/forum/...ead.php?t=5472
I have an extra oil pressure sendor around someplace and I can check to see what the thread pitch and diameter are. I think I also have the stock temp sendor, but IIRC it's a real oddball size.
Old September 29th, 2005, 04:51 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I believe the coolant temp sender is 5/8 UNF threading. I couldn't find an adapter at the time, so I ended up getting a plug and then drilling/tapping it in my lathe.
Mike, definitely post up the oil sender threads when you figure them out, I'll be doing that gauge next.
-Hans
My oil line fix
My 100k stopped odometer fix
Old September 29th, 2005, 05:14 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Jason,
For the coolant temp sender I run a 3/8-18 NPT tap into the original threads to taper them and then install a 3/8NPT sender. I just did a VDO oil pressure gauge on a D110. The original threads were #5 o-ring boss...so I got an adapter to fit a 1/8NPT sender. I bought an extra adapter if you need it....and I can order more if anyone else is interested.
Rob
Rob Dassler
SWR Automotive
505-872-7818 (shop)
fuel gauge ohm range naeirie Defender Technical Discussions 35 September 6th, 2017 02:49 PM
upgrade advice TND90 Defender Technical Discussions 5 October 16th, 2005 08:47 AM
OME upgrade advice kolvedic Defender Technical Discussions 11 August 16th, 2005 11:08 PM
FS/T: 1994 rear light units NASD90 For Sale - Parts 6 March 16th, 2005 02:20 AM
Upgrade pushed back chrisvonc Misc. Chit-Chat 0 May 15th, 2004 11:23 AM
