Diagnostic Code 48 - Defender Source
Old September 29th, 2013, 04:30 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
Diagnostic Code 48
My truck is displaying a 48 which, as I understand it, indicates a faulty idle speed stepper motor. Now it only does this when it is cold. Mine touches 2000 rpms before hesitating for about 5 seconds at 1500 then about 1250. It settles in at 1100 and gradually drops to normal idle speed as it warms.
What is the behavior of your D90 on cool, let say 60 degrees, start up?
Could a faulty temp sender cause this?
It has, on occasion, hung out at 2000 and 1500.
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old September 29th, 2013, 04:41 PM
sticky stepper ... when it's warm it can move more easily. Give it a clean.
I would start with a stepper motor since its cheap and easy.
Old September 29th, 2013, 04:43 PM
clean it and if that doesn't work the 1986 chevy astro v6 version is the same ... about $40 from your local parts store.
Error code 48 naeirie Defender Technical Discussions 0 June 7th, 2013 10:56 PM
Code 48 Stepper motor devinchi Defender Technical Discussions 8 September 8th, 2005 05:43 PM
yet another radio code question GliderKing Defender Technical Discussions 3 June 4th, 2005 05:06 PM
Fault Code Help howellm70 Defender Technical Discussions 1 January 30th, 2005 05:43 PM
