Diagnosis help from the experts-HELP! - Defender Source
Old February 25th, 2012, 01:00 PM
jsimpson
James Simpson
1995 Defender 90
At the end of my rope and need some help from you guys
Have a 1995 D90 that I bought this past summer. Barn Dweller that had been sitting for last 10 years. 40K in very good shape. Have been experiencing the following
Drives strong for most part. Feels like is it "missing" when in 5th...just a bit. Occationly when driving I loose power. If in gear it keeps moving along for about 15 seconds until power returns. If going slow it stalls out and then restarts after a few tries. If you pump gas when this is happening nothing happens. Seems to kind of correct itself and then on the way again. Feels like it is loosing fuel but my mechanic says different. He says it is electrical. Following work has been done
-new wires and plugs
-loose wire to coil fixed
-fuel filter replaced (was extremely clogged.
-One of cats was shattered-thought perhaps this was exhaust issue (clogged)
-replaced Front exhaust including both Cats as well as new muffler
Just picked up from my guys and doing same thing. What does it sound like to you guys? Fuel pump? What electrical to check? Worth trying a new coil? Any direction much appreciated
Many thanks
Jamey S
Salisbury CT
Old February 25th, 2012, 01:04 PM
I've had a similar problem to this and it turned out to be leaking air in the pipe between the plenum and MAF ... The big 3 inch diameter pipe. Mine always seems to work itself lose from time to time ...
Other than than ... The distributor advance tube also rots out and is worth changing ... Cost about $1 from autozone.
Ps I'm not an expert as my other current thread clearly demonstrates!
Old February 25th, 2012, 01:09 PM
jsimpson
James Simpson
1995 Defender 90
will take a look Jason. Many thanks. Know that it is always a process with these beasts but this one driving me nuts!
all the best
Jamey
clutch problem diagnosis help... bharris Defender Technical Discussions 18 November 14th, 2011 04:42 PM
Off Road Training weekend - Overland Experts in CT 3/29 & 3/30 pmd Trips, Trails and Events 2 March 19th, 2008 08:05 AM
OBD2 - P0420 Diagnosis pcscharfe Defender Technical Discussions 1 January 12th, 2008 02:28 PM
Overland Experts - winter drving.... dmarchand Trips, Trails and Events 5 October 2nd, 2007 05:02 PM
Clutch issue? Help with diagnosis..... Hans Defender Technical Discussions 13 December 18th, 2005 05:19 PM
