Diagnosing "tap tap" / rattling noise - Defender Source
Old May 8th, 2015, 10:52 PM
I never thought I would start up one of these posts, but here I am. My 90 is RHD, has a 3~3.5 inch lift, RTE radius arms, nitrocharger externally mounted shocks, swampers, but pretty much stock everything else.
At slow speeds, under 5mph, and usually while braking, my front end starts making a loud, definite, "tapping" or "knocking" noise.
There is no shake in the steering wheel.
I've attached a video with annotations marking on the onset of the noise.
I plan to take more videos of the driveshaft and tcase areas as well.
Old May 9th, 2015, 11:13 AM
sorry, having problems with the video uploading...
Old May 9th, 2015, 11:44 AM
one more time
Old May 9th, 2015, 12:04 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I have no idea yet what your noise is but that is a good video....how did you make it?
How and where did you attach your camera?
I also liked your intro; reminded me of those old Playboy letters...."I never thought it would happen to me, but there I was..." LOL
Rent my
Old May 9th, 2015, 12:35 PM
thanks jeff, the camera was attached to my front bumper via copious amounts of scotch tape.
jeff (other jeff), the sound does not go away when applying the brakes. It appears when I decelerate while coasting under any condition under 5mph.
The only time I can make it disappear is when I press the accelerator.
Old May 9th, 2015, 12:38 PM
87 D110 (Ruby)
driveshaft Ed? Take off front and see...then take off back (put front back on )
Old May 9th, 2015, 12:42 PM
good point jonesy. I am running a brand new tom woods double cardan (as of last fall) but maybe it's got problems...
Old May 9th, 2015, 01:42 PM
driveshaft video 1
Old May 9th, 2015, 01:54 PM
madcowdungbeetle
Carter
It sounds to me like a CV popping. I've gotten my sister's Disco to make a very similar sound and it was the CV.
Only other thing that comes to mind is a U-Joint in the driveshaft binding under low-load.
Old May 9th, 2015, 02:04 PM
Tom woods center bearing in the cardon beeds to be greased often or it will fail.
Mark Kellgren
KM4BOR
Old May 9th, 2015, 02:06 PM
driveshaft video #2
Old May 9th, 2015, 02:41 PM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
My thoughts exactly. Center bearing failure.
Old May 9th, 2015, 03:40 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Is it me or is that some oil spilling out of the drain plug at the end of the video?
MUDSUX
Old May 9th, 2015, 11:45 PM
Forrest, I'm afraid you're right. There is some kind of leak coming from the bellhousing hole. it's a small leak, but it's noticeable.
I replaced my rear main seal last year with a good dowty seal, but it seems that it is already leaking. Will have to replace it.
I'll check both CV's and the centering ball of the front driveshaft tomorrow morning. I'll also check the other suggestions that folks have made. I'm eager to get rid of these noises.
Old May 17th, 2015, 08:20 PM
1. Checked driveshaft. Greased all grease points including center bearing with needle adapter. Seemed alright.
2. Checked CV's. Right CV circlip had popped off under the cap and the CV was "pushed" into the drive flange, flush with the surface of the drive flange. Also noticed leaking inner hub seal on same side. Will fix both and see what occurs.
3. Found that I have a leaking injection pump. I've ordered a set of 200tdi timing tools and will remove the IP for service.
Not sure about the leaking rear main seal. It's difficult to tell if the drip is actually coming from inside the bellhousing or if it's actually leaking diesel fuel dripping off the bottom of the bellhousing.
Either way, will rectify one after another.
Old June 8th, 2015, 01:06 PM
Did some rover work over the weekend.
I found the source of the tapping. Those who mentioned the CV were correct. The retaining circlip on the outer CV had come off when I removed the rubber axle end cap. When I removed the cap, the outer CV joint was actually flush with the drive flange. After removing the stub axle, I found that the Front Stub Axle Bush (FRC4319) had actually come out of the stub axle and jammed itself between the stub and the CV, so the CV was actually cocked at an angle. Not good.
I pressed the bushing back into the stub, reassembled all with new gaskets and repacked bearings, replaced the circlip, and all is well again.
All suggestions mentioned in this thread were appreciated! Thanks again for your input.
(note for the future: the purpose of the circlip includes retaining the outer CV so it doesn't let the bushing pop out!)
Rattling / Banging Engine Noise OahuDefender Defender Technical Discussions 3 May 16th, 2013 05:59 AM
Crazy Rattling Noise From Exhaust/Underneath Wolf Fabrication Defender Technical Discussions 14 April 6th, 2009 07:12 PM
Diagnosing D110 Climate Controls 61rover Defender Technical Discussions 6 September 27th, 2007 12:13 PM
Need help diagnosing electrical issue cgalpin Defender Technical Discussions 22 January 25th, 2007 08:53 PM
