Diagnosing D110 Climate Controls - Defender Source
Old September 24th, 2007, 01:49 PM
61rover's Avatar
61rover
John Crouse
I'm trying to figure out what's going on with the heat/vent controls on my '93 NAS D110. Fan switch seems to work ok, but the three slides above it don't seem to do much. I don't think the intake vent in the wing is opening. Any guidance on diagnosing what is working and what isn't?
Old September 24th, 2007, 03:23 PM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
D110 Controls
I think that the control to open and close the outside air vent is operated by a vacuum hose. Mine is open, bringing in outside air no matter what position the lever is in. Last weekend I installed a new heater core, and noticed a rubber tube that was cut in the wing vent.
The lever to switch between cold and hot sticks. You will notice that on top of your heater/ac coil box (the black box on the right side in the engine bay) there is a cable on the top. You will want to put some penetrating oil into the cable like PB Blaster to free it up.
As for the fan speed lever it is marked 1-2-3-4, but my fan will cut out at position 4. I think it is the switch???
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old September 24th, 2007, 04:55 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Sounds like a vacuum problem. Richard made a nice vacuum schematic for the 110. Check it out here:
http://www.defendersource.com/forum/...referrerid=433
Old September 25th, 2007, 02:28 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
John, if you need a working model to look at, I'm down in Monument.
Jon, sounds like maybe the blower motor resistor has gone bad. Often there will be a blower motor resistor used to regulate the motor's speed. When you select a higher fan speed the blower motor resistor will provide less resistance to the blower motor allowing it to spin faster thus moving more air. I know this is a common problem on RRCs (http://www.roverparts.com/Instructio..._PRC8010_1.cfm). Not sure about Defenders though.
Chance
Old September 25th, 2007, 03:38 PM
R. Kurk
Richard Kurk
1993 110 NAS #489
John > Check out the diagram I made referenced in the link above by Ryan. If none of the controls are working start with the vacuum tank (‘Tank Vacuum #MUC 1679’) and the black hose running from it along the bulkhead and then into the interior. If this is leaking or can’t maintain a vacuum then your controls will not operate other then their ‘no-vacuum’ state. All of the vacuum switches controlling the various settings have a ‘no-vacuum’ position which will be the position (only position) if there is a leak. For example, the ‘no vacuum’ position for the fresh air/re-circulated air is to have the vent in the bulkhead near the ECM closed and the corresponding vent on the wing to bring in fresh air to the heater-cooler assembly open. The link I posted also discusses what was wrong with just one control-vacuum switch on my 110, you may have a similar and relatively easy fix (I hope).
Jon > My 110 would also not operate on speed number 4. I repaired this about two years ago and I believe from memory the fix was to replace the relay located at the top of the heater-cooler assembly. I also bought a blower motor resistor but this did not correct the ‘speed number 4’ problem. However (from memory again) the two parts, relay and resistor, if bad will effect which fan speeds work and how many.
I hope this helps.
Rich K.
Old September 25th, 2007, 06:37 PM
Jon_Winningham
Sterling M Archer
Thanks for the help guys...
Were any of you able to buy a replacement vacuum hose locally, and what size?
Old September 27th, 2007, 12:13 PM
61rover's Avatar
61rover
John Crouse
Thanks everyone for the input. I'll start checking vacum lines this weekend.
110, d110
Wanted 1993 NAS D110 Jon_Winningham Wanted 1 November 16th, 2006 10:20 AM
Project D110 hi-cap Shane@EVS Misc. Chit-Chat 9 February 26th, 2006 10:05 PM
D110 300Tdi AC Compressor? Hssser Defender Technical Discussions 3 August 17th, 2005 07:47 PM
Looking for a D110 kredwine Misc. Chit-Chat 4 August 8th, 2005 06:41 PM
Front GBR Extreme Duty 23/24 inner axles, D110 CV's and spindles w/ brass bushing lwg For Sale - Parts 8 February 9th, 2005 01:08 AM
