diagnosing air conditioning - Defender Source
Old July 7th, 2014, 08:29 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
I did a search for a thread on this but couldn't find one. If you know of one, please let me know...
I could use some advice with diagnosing an a/c issue. It was working fine, blowing cold, and now all of a sudden I don't even hear the fan going. Checked the fuse as usual, nothing there.
So where do you recommend I go next? Fan relay? Something else?
Thanks guys
Old July 7th, 2014, 08:48 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Find the low pressure valve/switch on the low pressure piping and use a paper clip or something like that and jump the terminals, if AC starts up you have low gas pressure. That's the first thing I check, easy first step, you can also check you have power or not at the compressor clutch, use that 12 volt test lamp that everybody has in their tool box?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old July 7th, 2014, 08:54 AM
That wont stop the fan from blowing.
Old July 7th, 2014, 09:04 AM
roverman2010
1985 LR 90 200Tdi
Depends which fan he is talking about?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old July 7th, 2014, 09:06 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Fan speed selector resistance or whatever this is called.
They burn all the time, but generally not all the speed at once.
Blower relay also but they generally don't give troubles.
- Charles Eames
Old July 7th, 2014, 09:07 AM
I have had trouble in the past with the main ground connection in the big brown multi-wire connector to the right of center on the A/C facia. It's one of the main harness connections. when I was having trouble, tapping that brown connection would cause it to start again (fan and a/c). Sometimes that brown connector would get so hot I couldn't touch it. All these issues were do to that unreliable ground connector.
I ended up pulling main ground (10awg) from both sides of the connector and using blade connections to join them directly instead. Not a single issue since.
Mark Kellgren
KM4BOR
Old July 7th, 2014, 10:30 AM
rankar's Avatar
rankar
Thanks guys for the info. Just to clarify, it is the fan speed selector. Turning the selector to any of the fan speeds does not turn the fan on, but I do hear what I believe is the compressor turning on.
Let me know if this triggers any more ideas. In the meantime, I'll get going with doing tests on the ground wire, switch, and relay.
Old July 7th, 2014, 10:36 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
I am willing to bet the fan switch is toast. You should be able to hard wire it to test it after you ensure it is grounded.
Old July 7th, 2014, 11:04 AM
The condenser fan will also run without any refrigerant in the system.
Old July 10th, 2014, 06:04 PM
rankar's Avatar
rankar
Just an update here... so I pulled out the a/c fascia and got access to the relay and switch.
1. I jumped the wires in the blower multi-switch (positions 5 and 2, brown and green) and no blower
2. I measured the voltage across the short I created and I'm getting 12V (but my ground lead was connected to the chassis)
So I'll try Mark's suggestion next to check the multi-connector ground.
So it seems like the relay is intact and the multi-connector to the blower switch is providing ample power.
If it's not the ground, do you think it's narrowing down to the blower itself?
Old July 13th, 2014, 07:58 AM
rankar's Avatar
rankar
Ok all fixed. Damn ground wire to the blower. I went looking around there with my inspection mirror, tugged on the ground very lightly and saw this... (thanks guys for all your help) Click image for larger version
Old June 22nd, 2015, 02:36 PM
Anschluss
T B
white 1997 Defender 90 NAS
I have just had a similar experience with my 97 D90. AC fan started to cut out intermittently and finally didn't blow at all. Thought I could hear the compresser kick in but no fan. As mentioned above, it was a loose wire underneath. Simple.
Hey... thanks to all of you amazing people who take the time to help point people like me in the right direction.
Old July 10th, 2015, 12:37 PM
bomilcar's Avatar
bomilcar
Stephen Miller
73 Series III Orig Owner
AC switches
Any one know where I can track down replacement switches for my 1994 Defender AC unit? Both temp and blower? Grounds are good but it seems that the blower switch is intermittent. I tried the obvious sources with no good fortune.
Steve
Steve
73 Series III (Original Owner)
94 D-90
2011 LR4
"anything that can go wrong has"
Old July 10th, 2015, 12:48 PM
phoenix37's Avatar
phoenix37
john
might want to ask these guys if they have something that would work.
Old Air Products - Home of the HURRICANE Heat, Cool, & Defrost A/C System - Underdash Pod
Old June 21st, 2016, 08:42 AM
bomilcar's Avatar
bomilcar
Stephen Miller
AC Pressure switch
More AC problems. 1994 D-90. Turned the AC on for the summer and it worked great for about 15 min and then shut down. Was scheduled to take it to my local dealer to change out the radiator and add duel electric fans. Added the AC problem to the service list. After some trouble shooting it was decided the culprit is the pressure switch (two lead). Turns out as expected the switch is no longer made. Checked with the usual mail order suspects with no luck.
Any thoughts or ideas would be greatly appreciated
Steve
94 D-90
2011 LR4
Old August 22nd, 2016, 09:15 AM
bomilcar's Avatar
bomilcar
Stephen Miller
I am still trying to track down an two lead AC pressure switch for my 94 Defender. Dealer has been unsuccessful. Tried Rovers north and BP.
Any one know an after market part number or have a suggestion on tracking one down?
Thanks.,
Steve
94 D-90
2011 LR4
Old August 22nd, 2016, 09:32 AM
Thanks.,
Pressure switches are generic. Remove it and figure out what thread it is and finding one should be easy.
That said its easy to bypass one with a jumper wire. They are there to protect your compressor but when the switch is whats bad and you know the system is charged correctly, I bypass them in the interest of comfort until a replacement can be sourced.
Old August 22nd, 2016, 09:52 AM
bomilcar's Avatar
bomilcar
Stephen Miller
Thank you Sir!
Steve
94 D-90
2011 LR4
Help Diagnosing a winch problem... bharris Defender Technical Discussions 8 April 28th, 2010 04:19 PM
Need Help Diagnosing Odd Sound fleabus Defender Technical Discussions 6 November 22nd, 2009 10:16 PM
Diagnosing Fuel Pump Issues hutch Defender Technical Discussions 40 May 21st, 2009 08:04 PM
Diagnosing D110 Climate Controls 61rover Defender Technical Discussions 6 September 27th, 2007 11:13 AM
Need help diagnosing electrical issue cgalpin Defender Technical Discussions 22 January 25th, 2007 07:53 PM
