Determine LT230 ratio from serial number - Defender Source
Old January 22nd, 2016, 10:31 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Is there a database out there somewhere that I'm missing that allows determination of transfer case ratio from serial number? I'm trying to verify its ratio - it's one I picked up from a board member. Thanks!
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old January 22nd, 2016, 10:40 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Ashcroft, yours is a 28e... For some reason I cannot open the tech specs on my phone. If you have your lap top click on the lt230 and scroll down there is a layout of all the ratios based on serial numbers. Looks like it's a 1.22... F#%^*~!!!!
Old January 22nd, 2016, 11:17 PM
ontheway's Avatar
ontheway
Dave
Yep, 1.22.
I had a feeling. The om617 is great but I barely ever spend much time in 5th gear. On the local hills I'm constantly shifting between 3rd and 4th to maintain 45mph.
Is it true that the ratio doesn't affect low-end? I'm having a hell of a time on hill starts... Really kicking my ass because of the low-power of the om617 before boost kicks in. Will it help when I finally get in a 1.4?
Old January 22nd, 2016, 11:19 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
All low gear ratios are the same 1.22,1.41, and 1.6
Old January 22nd, 2016, 11:30 PM
ontheway's Avatar
ontheway
Dave
Thanks gents.
------ Follow up post added January 22nd, 2016 11:36 PM ------
While we're on the subject - anyone have anything that shows the individual ratios of each gear through the 1.4 vs the 1.2? Just curious now
Old January 22nd, 2016, 11:50 PM
Gearbox ratios are here: Land Rover Gear FAQ
Why not just increase the power. You can do 250 hp.
Old January 23rd, 2016, 12:07 AM
ontheway's Avatar
ontheway
Dave
Originally Posted by Red90 View Post
Gearbox ratios are here: Land Rover Gear FAQ Why not just increase the power. You can do 250 hp.
True - but I don't think this particular om617 is a healthy engine. It can probably hold for many more miles stock; as they tend to do. Add more HP and maybe not!
------ Follow up post added January 23rd, 2016 12:10 AM ------
TeriAnns site has all the ratios. Land Rover gear ratios -Jeff
thanks... I'm going to have to try this tomorrow without whiskey... Too much math and numbers!
Old January 23rd, 2016, 12:16 AM
There are errors there and lots of missing info.
All possible options are in Ashcrofts ratio calculator and there are no errors.
Old January 23rd, 2016, 07:14 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Dave I have a guy that might be interested in the 1.2 if you decide to let it go
~ Semper Fidelis ~
Old January 23rd, 2016, 08:47 AM
Originally Posted by ontheway View Post
Yep, 1.22.
To clarify your low end question. The standard boxes all have the same low range gearing but the high range gearing is all effected. Ie 1st gear in a 1.22 is a full 30% taller than it was with your old 1.66 which is what I think you are asking.
Old January 23rd, 2016, 09:49 AM
ontheway's Avatar
ontheway
Dave
Ok thAnks Doug, that does help. Everyone else was saying low-range selection on the XC stays the same... You've clarified that the 1.22 makes 1st gear much taller. That's what I wanted to know. This may seem elementary to some, but the inner workings of gear boxes and XCs is still akin to the realm of 'magic' for me.
------ Follow up post added January 23rd, 2016 09:49 AM ------
I'll look for someone with a straight trade - especially in the NYC area
transfer box serial number grbec22 Defender Technical Discussions 1 August 3rd, 2010 02:40 PM
how do you determine what type of LT77 Gearbox I have? grbec22 Defender Technical Discussions 2 July 27th, 2010 08:20 PM
Rookie question... How to determine if my truck is lifted or not. KKilo23 Defender Technical Discussions 31 July 6th, 2009 10:55 AM
axle housing serial number Uncle Douglas Defender Technical Discussions 4 November 23rd, 2008 12:09 PM
telling the build year by the engine serial number cdb Defender Technical Discussions 2 August 16th, 2006 08:45 AM
