Determine clutch pressure plate wear - Defender Source
Old November 18th, 2010, 10:18 AM
How does one determine if a clutch pressure plate is worn or not?
Old November 18th, 2010, 01:18 PM
Anyone? Do they not wear/fail?
Old November 18th, 2010, 01:54 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I would just get it turned everytime you seperate the tranny to do the clutch or engine. The only bitch is the dowel pins, sometimes they come out easy, sometimes not. They have this puller thing, dosen't always work though, happened to my series III flywheel, I just had them machine them off and bolted the clutch cover to the flywheel, not enough power/torque on 2.25 to make a real problems.
Robert Deniro
Old November 18th, 2010, 04:18 PM
Old November 18th, 2010, 05:07 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
I changed mine whe the clutch started slipping. The friction disc was fine.
Keith
Big, Red and ... aaa Red..
Old November 19th, 2010, 07:14 AM
Interesting. OK, I'll stop being a CB and get the pressure plate too.
clutch
Clutch pedal has no pressure ttegt Defender Technical Discussions 4 June 28th, 2010 09:06 AM
Chattering Clutch - Help R. Kurk Defender Technical Discussions 1 June 26th, 2009 05:33 PM
T.O.B wearing groove into pressure plate fingers Noah Defender Technical Discussions 17 October 13th, 2006 12:00 PM
pressure plate jperakis Misc. Chit-Chat 1 April 27th, 2004 09:45 AM
