Detach Speedometer Cable - Defender Source
Old February 10th, 2005, 06:28 PM
Matt Klapmust's Avatar
Matt Klapmust
Matthew Klapmust
'94 D90 ST
Wanting to detach the speedometer drive cable from the back of the actual speedometer, anyone have any tips? Not sure whether it twists out or just pulls directly out.
Old February 10th, 2005, 06:38 PM
You push the sides of the plastic near the speedo together to release and pull out.
Old October 2nd, 2013, 01:43 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
What is the name of the plastic fitting that you squeeze to remove from the speedo?
I know for the 94 D90 NAS manual, the upper cable has a 3/8 18 female on the other end.
I may fabricate one.
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
ac, speedo
Speedometer cable mod for VDO - shop? mgrgpg Defender Technical Discussions 20 December 27th, 2013 11:57 AM
Upper speedometer cable 94 NAS D90 Kilgore503 Wanted 10 February 18th, 2010 12:59 AM
Upper Speedometer Cable rmuller Wanted 0 May 1st, 2008 11:58 AM
speedometer cable for 1984 110 cgalpin Defender Technical Discussions 18 April 4th, 2008 09:28 AM
Speedometer cable... standard threads down below? Hans Defender Technical Discussions 0 January 13th, 2007 09:33 PM
