Dent Repair on inside of Tub - Defender Source
Old September 18th, 2016, 01:16 PM
Before I Ron good this, any tips? Do I heat or not? I was going to jack from underneath and hammer on the side. Need to get it fixed as I am springing for a new mat and want it to look nice. Need not be perfect.
Second pic.
BTW it has been like this since I bought the truck the first time in 2002 or so.
Old September 18th, 2016, 01:23 PM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
I would hire a cheap mobile paintless dent repair guy. I had a creased rear quarter panel and difficult to see where it was. Aluminum is tougher to deal with but if does not need to be perfect than should be easy repair or bfh and a block of wood
Old September 18th, 2016, 01:33 PM
So no heat?
Old September 20th, 2016, 11:00 AM
Naplm00
Matthew
Heat will make it brittle, I'm assuming
Old September 20th, 2016, 11:48 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
That depends if know how to use the heat....
Rent my
Old September 20th, 2016, 11:51 AM
Second PDR...but the probability of Ron hiring a anyone to fix this is about as high as him hiring anyone to fix his mansion
The Ron good way of fixing this is without heat. Use some smooth hardwood board clamped across the back of the aluminum as the buck. The die (the part that you hammer on) should be a smooth piece of hardwood as well. Never hammer directly on the aluminum. Just on the die. ultimately what you are doing is squishing the aluminum flat between two smooth, flat surfaces. Essentially cold-forming.
You need a die and a buck otherwise the result will look pretty ripply. If it comes out somewhat ripply, you can fix with an orbital sander to make flat.
Old September 20th, 2016, 12:09 PM
On the average day, there are three people working on the mansion, and I am not one of them.
I just need to retain a inhouse rover mechanic. I am trying to teach the house boy but since he is back in college he is not there as much as over the summer.
Old September 20th, 2016, 12:25 PM
Al Blue4.6l's Avatar
Al Blue4.6l
Allen
2006 LR3
I love Kirkham cars and that video is amazing.
Old September 20th, 2016, 12:59 PM
pshaw's Avatar
pshaw
Peter Shaw
1965 SIIA 88"
There are actually BirmaBright dent repair instructions in the series workshop manual, with instructions on heating the panel before working out dents. Aluminum work-hardens VERY quickly, in fact the initial dent has already caused some work hardening to occur and hammering out the panel could eventually lead to cracking the aluminum. You could probably get away without heating/annealing it as long as you don't over do it. See section 76-1 Body Repairs.
Old September 20th, 2016, 01:20 PM
It's already Ron Good... Why would you bother to add a new rubber mat? :-)
Old September 20th, 2016, 01:29 PM
I think Birmabright (series) body panel repair is somewhat different from Defender aluminum repair. Birmabright is an Al-Mg alloy (5000 series) while Defender body panels are Al-Mn (3000 series).
Thankfully, the rate of work hardening in 3000 series aluminum is significantly lower than 5000 series - almost as low as 1100 series (As observed experimentally, Defender body panels are softer than Series panels.)
The Birmabright techniques probably apply to Defender body panels, just not nearly as difficult to form.
I really do not recommend heat for flat panels on defenders. I have done this several times early on in my repair attempts (2011-2012ish) and the rate of thermal expansion is massive. You can actually see the entire panel warp from the heat of a propane torch. The end result is that the aluminum may or may not be permanently warped with the simple application of heat. It's not worth the risk (IMHO) to simply beat out a small portion of a much larger panel. The Defender aluminum is incredibly soft and can be cold worked.
Old September 20th, 2016, 02:25 PM
To cover the holes from where the rear seat was.
Dent repair jayz Defender Technical Discussions 5 June 18th, 2011 12:31 AM
easy dent repair D90? hlamar Defender Technical Discussions 14 August 6th, 2010 12:25 PM
Where can I find the pads that go on the cage bar inside the SW? Pic inside... KKilo23 Defender Technical Discussions 6 June 26th, 2009 05:36 PM
Scratch and Dent Trail - Colorado USA chrisvonc Trip & Trail Reports 0 June 19th, 2004 09:39 AM
Scratch and dent bonnet ronward Wanted 2 January 13th, 2004 11:32 PM
