Demello Offroad Hi-Lift Mounts - Defender Source
Old January 24th, 2012, 12:11 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Has anyone tried these hi-lift jack clamps from Demellow Offroad? At 1.75", these should work nicely on the NAS bars.
http://www.demello-offroad.com/catal...roducts_id=116
Name:	DO hi jack clamps.jpg
Old January 24th, 2012, 12:25 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
They look nice but also overpriced. I run the Hi-Lift clamps (can be found at a number of vendors for under $50) on mine and they work great
http://www.hi-lift.com/accessories/tube-mount.html
or you could buy a couple of two piece shaft collars from somewhere like McMaster for ~$15ea and drill/tap them for a stud
Old January 24th, 2012, 04:58 PM
cdb
Clark Bowen
Have a similar pair that I bought from a different company.
Overpriced and quite convenient.
I used to just run bolts up through my offroad light tabs, drill near the top for a small padlock and use wingnuts to tighten down.
Cheap, works great and more secure that these aluminum doodads.
Got hot for the ones like you are looking at and now they sit in a parts box.
Save your money, unless bling is your thing.
2011 RR HSE -
2001 GMC 2500 4wd
mount
Tires sizes per lift ratio ini88 Defender Technical Discussions 9 December 22nd, 2005 01:02 AM
Installing engine mounts Doug Defender Technical Discussions 4 February 23rd, 2005 06:49 PM
Inexpensive, minor lift ideas sought.. LRNAD90 Defender Technical Discussions 1 September 16th, 2004 06:59 PM
weld on motor mounts pendy For Sale - Parts 3 September 8th, 2004 03:10 AM
Expeditionware shock mounts dave_lucas For Sale - Parts 4 September 1st, 2004 04:20 PM
