Delayed cranking in TDI - Defender Source
Old February 15th, 2016, 09:08 PM
Matt_110's Avatar
Matt_110
Matt
110
After sitting for a long time (2 years or so) I changed out the fuel filter and primed the system. Yesterday and recently it has been starting normally as I move it around the driveway. However, after I changed the filter now instead of cranking over immediately it turns over 5-9 times before firing up. Could there still be air in the system?
Also, the diesel that was in the filter had a honey/amber look to it. Since the tank was empty, I added 2 gallons of good diesel and some Power Services diesel injector cleaner. Edit: 2.8TGV, freshly charged battery, starter spins fine, Engine is new.
1987 110, 2.8TGV, ZF Auto
Old February 16th, 2016, 12:58 AM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Since the engine is new, is this a replacement for another diesel or a conversion from gas?
Black Rhino Lives Matter
Old February 16th, 2016, 06:35 AM
Matt_110's Avatar
Matt_110
Matt
110
It was a conversion from gas. But it was cranking fine recently. I ran it 2 days ago to make sure my gauges were working since I'm in the middle of putting the dash back together. I went to start it the next day and it wouldn't fire. The fuel gauge read empty so I put some more in and changed the filter. I had to prime it a couple times but it is still taking a while to start.
Old February 16th, 2016, 07:35 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You most likely have trapped air, but could also have an air leak.
If you want a robust self bleeding fuel system that will eliminate your fuel problems, here's what you do:
The optimal routing for a self bleeding fuel system is:
Tank -> Sedimenter -> 12V fuel pump -> lift pump -> filter -> IP -> return line from IP joins with Injector spill over -> straight back to the tank.
I am no fan or the original plastic lines that over time split and leak or develop leaks when kinked.
Any part of your fuel system past the fuel pump sucking air will be exposed under pressure from the 12V fuel pump.
If you do have a leak, it will be identified so you can fix it... otherwise will go unnoticed.
Hope this helps
RDavisinVA
Old February 16th, 2016, 11:36 AM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Did you remove the inline gas filter?
Old February 16th, 2016, 11:39 AM
we really need a lot more information on the conversion. People do conversions different ways. How is the entire fuel supply system setup?
Old February 16th, 2016, 12:03 PM
Matt_110's Avatar
Matt_110
Matt
110
This is how it is set up. It was a frame off install with the M&D kit. New tank and aircraft grade fuel supply and return lines straight from tank to lift pump -> filter -> IP -> injectors and then leak-off return. If I remember correctly the proper fuel pickup tube was not used and instead one was "fabbed" up. I'm wondering if this might be causing air to enter the system if the pickup isn't located deep enough. Here are some pics for reference. Click image for larger version
ID:	142524 Fuel lines routed into chassis Click image for larger version
ID:	142525 Up to engine bay Click image for larger version
ID:	142526 Click image for larger version
Old February 16th, 2016, 12:09 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
You don't have an electric fuel pump by any chance, do you?
Old February 16th, 2016, 12:14 PM
Matt_110's Avatar
Matt_110
Matt
110
No I don't. I know some folks fit one, but I'm not sure if it's necessary? And sedimenters...again not sure. Maybe I need both. I am trying to find the right pickup tube for my peteol style tank. Maybe that'll solve the issue. Tried to start today and same long delay
Old February 16th, 2016, 12:17 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Certainly not required, but you could rule out some issues with one. Also easier to bleed the system of air
Old February 16th, 2016, 12:51 PM
Matt_110's Avatar
Matt_110
Matt
110
That's what rdavisinva suggested too. I'm guessing I would mount this along the chassis towards the back? Is wiring difficult?
Old February 16th, 2016, 01:13 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Wiring is very easy, but I would talk to Robert about how to do it best.
Old February 16th, 2016, 01:23 PM
Matt_110's Avatar
Matt_110
Matt
110
I just bled the filter housing and then cracked open the 2nd injector. I turned it over a few times and nothing really came out...not enough to notice on the rag. The filter seems full. There are a few bubbles then it oozes straight diesel. She starts up, but only after I go through this dance a couple times.
Old February 16th, 2016, 01:24 PM
You do not need the complexity of an electric pump. Just fix the air leaks. Adding another pump without fixing the leaks is a bandaid and hides an existing problem.
A sedimenter is a good idea though as the lift pump check valves tend to get plugged when you do not have one and causes the lift pump to not work.
Old February 16th, 2016, 01:26 PM
First check that the lift pump is working. Disconnect the line after the fuel filter and crank away. You should get a good strong flow of fuel. The lift pump should bleed the system on its own with no trouble.
Old February 16th, 2016, 01:30 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I use the electric pump to find the leaks, then fix. I agree it's not necessary, and will add to the complexity of the system.
Old February 16th, 2016, 01:38 PM
Matt_110's Avatar
Matt_110
Matt
110
Good tip...it's always the easiest stuff sometimes. I'll take a look after work.
Old July 16th, 2017, 12:06 PM
Matt_110's Avatar
Matt_110
Matt
110
Just to close this issue, it turned out to be a wire that detached from the back of the ignition switch. Starts like a champ now. All the headaches and money I dropped into trying to sort it out is laughable. I knew it had to be something simple. Almost bought a new IP
Extremely Delayed Delivery of a 110 from Vendor(Need Advice) JehovahNissi77 Misc. Chit-Chat 279 April 15th, 2015 01:09 PM
Not cranking. bjp Defender Technical Discussions 11 December 24th, 2012 01:37 PM
Hand cranking a V8 ini88 Misc. Chit-Chat 3 July 25th, 2011 05:23 PM
Cranking/Running Problems Landy1 Defender Technical Discussions 8 May 2nd, 2009 02:48 PM
