defroster rant - Page 2 - Defender Source
Old December 10th, 2013, 04:01 PM
Originally Posted by FSU_Disco View Post
Have you enlarged yours at all?
Yes. I have a heater that has twice the air flow and three times the heat output (measured in the vehicle). Everything has been made larger. Before and after the change, I measured the flow rates and heat outputs, both in and out of the vehicle.
It is much more heater than a 90 needs, even at -40. Would be really nice in a 110.
Old December 10th, 2013, 04:05 PM
My stock heater was flowing 240 cfm at the inlet out of the vehicle and 160 cfm in the vehicle with the deflectors removed. The bulkhead area does not calculate to be "very" restrictive with the stock heater, but probably contributes a bit. You would need to open up the lower vents first. I'm not sure if NAS trucks have different vents.
Old December 10th, 2013, 05:39 PM
BUT...keep in mind I firmly believe it's the bulkhead cutout along with the fan that make the diffference overall.
AND...keep in mind I already did the cutout to my bulkhead
Mark Kellgren
KM4BOR
Old December 10th, 2013, 06:04 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
this has been a very informative and helpful rant
Old December 10th, 2013, 06:37 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
I cut the hole in the bulkhead while I had the engine out. Interested to see how that goes. And while taking apart the dash the grommets for the defrost tubes were half on/half gone. Curious to see how that helps.
defroster
hazard, dash, defroster switch retainer isleofbones Defender Technical Discussions 10 October 21st, 2012 06:07 PM
Diesel cars (or lack there of) rant evilfij Misc. Chit-Chat 40 January 14th, 2011 01:05 PM
Beltway psychos - rant hillstrubl Misc. Chit-Chat 20 October 15th, 2010 10:55 PM
NAS 110 Front Defroster Light bjf Defender Technical Discussions 7 January 14th, 2010 01:43 PM
110 Front and Rear Defroster Switches bjf Defender Technical Discussions 12 April 22nd, 2009 12:30 PM
