DefenderVent - New Side Vent - Defender Source
Old December 5th, 2008, 10:05 AM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Anyone use these yet??
http://www.wiberg-wiberg.com/vis.asp?v=gruppe&gid=88
Looks easy to install and make sense. Click on the PDF for the install.
I'm ordering one to try it out.
Old December 5th, 2008, 10:42 AM
Looks neat - I love the Germans for stuff like this. Thats a lot of effort to solve a small problem.
Anyway, I'll look forward to hearing about how it works out, I could definitely see myself installing that.
Old December 5th, 2008, 11:37 AM
xrover's Avatar
xrover
Len Cater
1997 D90
I need help with my german. Do they only ship the end vents and hose or is it is a replacement vent with the extra air outlet on it as well.
It's a brilliant idea either way.
'97 D90 NAS
'06 Argo Avenger
Old December 5th, 2008, 12:14 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
It's actually Danish!
Semper Fi!
Old December 5th, 2008, 01:19 PM
Len, click on the PDF and it explains the process. You drill holes in your current ends and add the round vents.
Old December 5th, 2008, 01:45 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I think he was referring to the defroster vents, which I think are supplied new with an outlet for the tube to attach to.
Old December 5th, 2008, 01:48 PM
Yeah sorry, completely misread his question. I agree it looks like they give you new vents.
Old December 5th, 2008, 02:17 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Just got emailed back. They send new vents with the "plug" for the smaller hose for the side vent, the hoses, and the side vent piece for the side of the dash.
Old December 5th, 2008, 02:34 PM
Neat idea. I've always wondered why rover hadn't done exactly that-its so simple
Old December 5th, 2008, 02:51 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
I always wondered why they couldn't actually 'de-mist' the whole windsheild. LOL!
~Scott T.
'95 D-90 ST - AA Yellow
Old December 5th, 2008, 03:53 PM
xrover's Avatar
xrover
Len Cater
1997 D90
I may have a look myself and see if a abs plumbing joint can be glue in to do the same thing and keep the original vent. You can get male connectors with a foot to cement to the side, drill your hole and then pick up a small vent for the grab handle. hmmm............
'97 D90 NAS
'06 Argo Avenger
Old December 5th, 2008, 06:20 PM
When I converted to LHD I did the trick shown on ECR's website where you open up the hole through the bulkhead and the heater plenum/lower dash to match the output flange of the heater box. This increases the flow from the heater by about 45%-a huge difference. The windsheild clears really quickly now and I'm running a cold natured diesel. The doors are still another matter.
Old June 27th, 2009, 02:48 AM
I am very interested in doing this modification during the summer when I get back from Iraq next year. I have heard about this several times, but never could find any specifics on how to do it, and exactly what shape/dimensions to cut when I do. Does anyone that has done this have pics and details? If I'm going to drain my A/C and coolant to do this, I'm hoping to eliminate any surprises, and definitely don't want to screw this up, as this would be labor intensive to recover from.
Old June 27th, 2009, 11:27 PM
D90DRC
D Cantrell
1997 D90SW
Those are made by mudstuff.co.uk not the Germans
http://www.mudstuff.co.uk/DefenderVENT.shtml
Still waiting for the Hope and Change to start
Old June 29th, 2009, 10:07 AM
Kev Baldwin
Kevin Baldwin
2.4 Tdci 110 Utilty Wagon
Errr, we can't take the credit for that one. We source the vents from the designer/manufacturer Wiberg & Wiberg in Denmark.
FWIW. The replacement screen vents supplied with the kit also has a larger opening than the stock vents.
LR did offer their own version of sorts for cold-weather spec Wolf Defenders. LR used new dash end panels fitted with (crude) mesh vents and a replacement heater air box assembly that had a couple of piped outlets to connect to the side window vents. I have been lead to believe (from a customer) that this kit is no longer available although I must confess I've never tried to source the parts myself.
Kev B
MUD-UK
Driver's Side Vent Cover on 97 specops1526 Defender Technical Discussions 6 June 10th, 2009 08:34 PM
110 Vent on far right of passenger side bjf Defender Technical Discussions 2 May 20th, 2009 03:01 PM
1995 AC circle vent on passenger side evilfij Wanted 6 February 27th, 2009 11:29 PM
Right Side HEater Vent Joe P Wanted 0 November 6th, 2007 10:56 AM
Drivers Side Wing Top Vent Troys Wanted 0 November 20th, 2006 09:40 PM
