Defender Wont start - Defender Source
Old March 21st, 2016, 03:18 PM
Saltlife Defender
Brenden
1989 Defender
Defender Wont start
I just purchased a 1989 110. It arrived in the US, had a little difficulty starting. started a few days if i hit the gas while starting. Then it did not.
Took it and got the carburetor, tank and fuel lines cleaned. Started better, then died. put a new air filter in, started much better for two days, Now has completely died.
It turns over great, but the motor just wont catch, I have checked the battery and added more fuel. I just cant get it to start.
Any advice would be greatly appreciative, trying to save the money from getting it towed to the mechanic.
Old March 21st, 2016, 03:34 PM
MisterSHO
David K
87 110, 95 RRC
Is it the 3.5? Manual choke?
Old March 21st, 2016, 03:44 PM
BlackField's Avatar
BlackField
Oscar
D110
Wires, plugs and rotor?
Old March 21st, 2016, 04:01 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Originally Posted by Saltlife Defender View Post
Took it and got the carburetor, tank and fuel lines cleaned...trying to save the money from getting it towed to the mechanic.
Is your mechanic a Land Rover specialist?
E.G., if you took it to Pep Boys to get the carb cleaned...
Old March 21st, 2016, 05:26 PM
Saltlife Defender
Brenden
1989 Defender
Yes he is a Land Rover Specialist, very trusted in the area, and yes manual coke. I just tried to turn it over for 30 seconds, pump the gas three times, pull the choke and then start it again but nothing.
Old March 21st, 2016, 06:30 PM
cowboy
steven
Ok, good on you for using a LR specialist. What the mods here & elsewhere tend to post is that you should download the service manual for your beast & to start in on the checklist for "no start" situations. Blackfield brought up plugs & wires - is there any indication that it has had a tuneup in recent years? - if not, plugs can usually be had from local stock & wires can often be had same-day or next-day. In the meantime, putting dielectric grease in the spark plug boots can possibly get you started, especially if it's a wire issue. And can you hear your fuel pump coming on when you turn on the key? Do you know how to check for spark?
Also, I'm probably speaking above my pay grade with this, but you probably want to keep it on choke when you're actually trying to start it. Anyone?
defender, start
defender twin carb wont start bonelesscandy Defender Technical Discussions 20 September 9th, 2015 08:52 AM
Defender 90 (97) wont start when motor hot? wolfgang Defender Technical Discussions 24 March 30th, 2011 05:16 PM
truck wont start jimmy salmon Defender Technical Discussions 26 December 3rd, 2008 01:44 PM
Yet another Truck Wont start... arbik Defender Technical Discussions 12 September 21st, 2006 03:51 AM
HELP - D90 wont start....going camping on Thurs TurkD90 Defender Technical Discussions 6 July 25th, 2006 09:49 AM
