defender wheel arch removal - Defender Source
Old March 31st, 2009, 06:44 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
Cool defender wheel arch removal
I am looking to remove my faded old wheel arches and respray them. They are fastened with what appears to be plastic rivets... there is a round head with a dimple in the middle. Do I push the dimple in, remove from the side that isn't facing the wheels,etc. My defender restoration guide(Haynes) is of no help as it talks about removing sheet metal screws and retaining clips(my truck has neither). In short, any tips on removal before I risk butchering the plastic rivets.
Old March 31st, 2009, 07:32 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
The easiest way to do it is to use a small punch to push the center piece all the way through, then the rivet will just pull out. Be careful not to lose the little stem pieces when you push them through, otherwise you will have to buy new ones. They are pretty cheap, but are reusable if you remove them carefully.
Old March 31st, 2009, 07:43 PM
isleofbones
Mike Deery
1984 D-90
Thanks, sounds easy!
Old April 1st, 2009, 09:01 AM
bitz's Avatar
bitz
Jon
NAS D90, 85 D110 CSW, 66 Dormobile
I just pop them with a screw driver and get new ones. It's a lot easier. They are pretty cheap. Safari Rover has them. It will save you a lot of time.
Old April 4th, 2009, 06:11 PM
isleofbones
Mike Deery
1984 D-90
Thanks Jon-
Both responses answered my question well.
Old April 4th, 2009, 08:04 PM
It is just as quick to do it properly.
wheel
Defender Steering wheel center shawnpalmer Wanted 17 October 17th, 2006 08:06 PM
Extended wheel arch flares? THP90 Defender Technical Discussions 1 August 31st, 2005 02:26 PM
Wheel Arch Protectors/Eyebrows boshea Defender Technical Discussions 2 June 29th, 2004 11:28 AM
Steering wheel removal? howellm70 Defender Technical Discussions 5 February 5th, 2004 06:14 PM
