defender v8 3.5 lpg help - Defender Source
Old January 11th, 2016, 09:59 AM
jimjames2uk
jamie
defender v8 90 1992
not sure if anyone can help or not have couple questions on lpg 3.5 efi defender
1. what is the recomended static timing for the 3.5efi
2 what would be the best timing for the lpg system
am changing the plug do i need to regap them smaller for the lpg
or if someone can point me in right direction of forum that can helps
Old January 11th, 2016, 11:35 AM
Departing90
Sasha
95 D90
The EFI system on the 3.5 Rover is basic with a ECU that controls the fuel / air mixture via again basic sensors. Timing is set and and can be slightly adjusted by tye distributor as in distributor rotor points to cylinder #1 and timing mark on harmonic balancer lines up for TDC. If the engine was running well prior to tye installation of the LPG unit I would strongly suspect the LPG unit or tye installation. Might be better if you posted on a UK forum where people have much more experience with the particular LPG system youve installed or try calling tech support of tye manufacturer.
Old January 11th, 2016, 12:46 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Jamie:
You won't find a lot of people here running LPG.
Here is an interesting article:
http://www.acl.com.au/web/acl00056.n...e?OpenDocument
In order to get the correct timing advance, the distributor would have to be fitted with different or modified weights and springs to alter the advance curve.
RDavisinVA
defender, v8
1988 Defender 110 V8 CSW gas/LPG looks/runs nice, great project or driver $12500 ZombieMotors For Sale - Vehicles 6 March 3rd, 2013 04:28 PM
Is LPG...LPG? atpick Defender Technical Discussions 12 June 9th, 2011 09:04 AM
Lpg? atpick Defender Technical Discussions 12 November 6th, 2010 08:31 AM
LPG Natural Gas Conversion Kit bstraw For Sale - Parts 0 December 16th, 2006 04:58 PM
LPG addition to Diesel motors little black duck Defender Technical Discussions 5 November 24th, 2006 11:52 PM
