Defender transmission issue - Defender Source
Old November 8th, 2014, 04:57 PM
Spanish Fly
Carlos Soldevila
1990 Defender 90
I own a 1990 Defender 90
I've started having problems shifting into second gear when the engine is cold. (The other gears shift great all the time.)
For the first five minutes of a day's first drive, I have a hard time engaging second gear and there is a grinding noise (gear not engaging) when I try to shift into second. Once I get rolling, it shifts perfectly for the rest of the day.
I did change the oil in the transmission (75w 90 synth), and I am not sure but I think it coincides with the problem -but it is also coincides with the weather getting colder outside, so, I I'm not sure which is the cause, if any!.
any advice out there?
tks in advance
Old November 8th, 2014, 05:00 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Are you sure the trany takes gear oil ?
Some manual transmissions actually use ATF.
Old November 8th, 2014, 05:06 PM
tks in advance
75w90 is transfer case lube. Try redline mtl, royal purples synchomax or similar. Thicker oil makes it harder for the synchro's to align.
There is a pump of sorts inside the trans to lubricate crucial parts and thick oil doesn't work well with that either.
Old November 8th, 2014, 05:08 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
You need ATF in this gearbox!
Old November 8th, 2014, 05:12 PM
Spanish Fly
Carlos Soldevila
1990 Defender 90
thanks!
I changed all the fluids at once and did use 75w 90 synth for the transfer case...
Did I make a mistake for the tranny?... really seems like it!
Old November 8th, 2014, 05:15 PM
if you put 75w90 in it you did
Old November 8th, 2014, 06:47 PM
redline mtl, pennzoil synchromesh, or honda mtf. i've used all three and all work fine.
your synchros are going to have a problem running 90w for sure.
Old November 22nd, 2014, 03:20 PM
Spanish Fly
Carlos Soldevila
1990 Defender 90
Replaced the oil by ATF: problem solved!
Thanks for the help.
Old November 22nd, 2014, 04:41 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Old November 22nd, 2014, 08:09 PM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
I have the exact same issue from 1st to 2nd and I just thought it was characteristic of the 1994 transmission which I believed on NAS versions they changed to a new transmission in 1995. So are you saying automatic transmission fluid will help with this? If so what brand is recommended? My 1994 5 speed has always done exactly what Spanish Fly was experiencing.
Old November 22nd, 2014, 08:13 PM
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
everybody says that the transmission is hard from 1st to second. I think they might be confusing the extreme low range of 1st gear and the less than german synchronization. Heck the old 4 speeds loved to shift out of second all by themselves
Old November 22nd, 2014, 08:51 PM
Spanish Fly
Carlos Soldevila
1990 Defender 90
this is what I've put : CAM2 Dexron-VI Multi-Vehicle Full Synthetic ATF
shifting into second gear is now a charm, even on a "very" cold Canadian start.
defender, transmission
manual transmission issue ditskovich Defender Technical Discussions 17 May 24th, 2012 09:09 PM
transmission issue? bschmeiser Defender Technical Discussions 14 October 28th, 2011 02:17 PM
1997 Defender Issue...Need some advice NDRover Defender Technical Discussions 19 June 30th, 2011 12:46 PM
Defender issue huck1974 Misc. Chit-Chat 1 March 26th, 2010 02:01 AM
Transmission or torque converrter issue?? gas-man Defender Technical Discussions 10 March 11th, 2010 01:24 PM
