Defender trans in D1 - Defender Source
Old January 30th, 2008, 08:19 PM
mpsteil
Michael Steil
NAS 110#23,97 ST#665
I have a R380 for sale and I am trying to find out if it will work in a 97 D1. I have been told that it will work but the bell housing is different. Can this just be swapped out with the D1 housing? I have also heard the Defender bell housing is hard to come by and might be worth some dough. Am I right or way off. Thanks, Mike
Old January 30th, 2008, 09:04 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Damn what are you smoking and where can I get some? Just Kidding. Definately everything from the bell housing to the LT203 is different, including the crossmember. You'll have to find a disco clutch pedal box, an R380 with the right length mainshaft, piping and ditch the oil cooler stuff. Might even have to change the flywheel, I'm someone can shed light on that.
Robert Deniro
Old January 30th, 2008, 10:04 PM
mpsteil
Michael Steil
Thanks, Neil. You want to buy the trans? When I bought it you were trying to get it also. PM me if you are interested. Mike
Old January 31st, 2008, 02:28 AM
Shane@EVS
Roverhybrids
the difference is mainly the shifter, which requires about 4 hours labor to change out the internal rod.
Old February 1st, 2008, 09:48 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Talking about smoking? The clutch pedal box has nothing to do with the transmission fitting or not.
As for the OP, I'm planning on putting the transmission from my D90 in to my DI, so will be able to tell you what needs changing in a couple months. Probably not soon enough for you though.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
94 NAS Defender 90-P.O.E.(Port of Entry) 1 of 65 made! on EBAY SeanD-90 Misc. Chit-Chat 29 May 27th, 2017 08:14 AM
Whats in my container??????? SafariHP The Vendors Loft 30 November 26th, 2015 07:31 AM
Is there a list of common parts from D1 to Defender? btate Defender Technical Discussions 1 February 16th, 2009 10:49 AM
ZF trans temp? dmarchand Defender Technical Discussions 2 May 17th, 2004 10:45 AM
» Defender Registry
Broken
Z.G
#304
TRS
Add your Defender
