July 11th, 2017, 08:54 AM
Originally Posted by brdhmltn
Which type will the Cummins use?
Not sure yet. Don't have the transmission to mock things up, have several of ea type
July 11th, 2017, 11:51 AM
Keith Armstrong
Various
Originally Posted by Nomar
FWIW, I just use an old cheap bottle jack that has a small round lifting point for my frame spreader/xmember remover.
I cut a piece of square metal tubing and put a bolt through the end for the jack to push on.
Total cost was $0.00 since I was using a jack I already owned and scrap metal.
Man, I just banged a chunk of 4x4 in there and knocked it out when I was done.
I considered the hi-lift but it was behind a pile of "inventory"...yeah, that's what it is, inventory
July 11th, 2017, 12:00 PM
Guess Who?
N/A
Originally Posted by Josh Ashcroft
You're saying in 1986 3.5V8 110's came with different cross members to accommodate different exhaust configurations?
I already know the style I need in this circumstance. Just trying to understand what the discussion is about.
So am I.
Now we know you have a 3.5 V8, noted above.
In Post 1, you made no mention of the engine option your vehicle has, see below.
Post 1:
I just bought a '86 110 and failed to notice the missing transmission crossmember until I got home. I have a spare for an '88 RRC that appears to be the correct size and bolt pattern, however it's quite snug and will require a jack to spread the frame a bit. I just want to make sure that the distance between the frame rails is actually the same on a Defender and a Classic before I go spreading anything. I'm having a hard time finding drawings with the exact dimensions I'm looking for.
Anyone know offhand if they are the cross-members should be swappable between a 110 and an RRC?
RDavisinVA
July 11th, 2017, 11:02 PM
Originally Posted by rdavisinva
So am I.
I was just clarifying that the distance between frame rails should be the same because mine was clearly off. I should have mentioned the engine but I was fairly certain it didn't affect the frame rail spacing.
Crossmember is in my truck, thanks all for the information.
July 12th, 2017, 10:00 AM
Guess Who?
N/A
Understood.
Was just trying to clarify and help prevent you from trying to put a RR Classic V8 X-member into a TDI vehicle for example.
Glad your missing x-member problem is solved.
RDavisinVA
» Recent Discussions |
