Defender Td5 - which engine oil - Defender Source
Old September 28th, 2011, 02:55 PM
berti1554
Robert Klima
84/110
hey guys!
somebody i know from a german landrover forum is touring thru the us w/ his defender td5 my 2003 right now. he has to do an oil change but is not sure which oil to use. as european and us specs are a little different, is there an oil you can recommend? he is using a Castrol 5W40 A/B3 right now. can he get this oil somewhere in the us (not sure where exactly he is at the moment) or is there something similar?
i'm in europe at the moment so i'm not a great help for him. would be super if you guys could recommend something.
thx!!
robert
Old September 28th, 2011, 02:58 PM
Naplm00
Matthew
Ive been using the Rotella full syn T6 is rated at 5W40 and is readily avail
http://www-static.shell.com/static/c...rotella_t6.pdf
edit this was in a 200tdi
Old September 28th, 2011, 07:04 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Copy what Mathew says - I use Rotella and buy it at NAPA.
Old September 29th, 2011, 04:11 PM
berti1554
Robert Klima
84/110
thanks guys, i will let him know...
Old September 29th, 2011, 11:44 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
Yep, some of the best stuff out there. My brother and me use it in everything from my '84 MB 190D to my 2003 Jetta TDI to the D-90 to the '80's era Yamaha motorcycle. All oil analyses that I've done show it holds up amazingly well.
engine, td5
Defender 200tdi...oil pressure sensor and diff lock switch sonoronos Defender Technical Discussions 4 July 28th, 2011 05:10 PM
first oil change after breaking in new engine Davis Defender Technical Discussions 15 May 2nd, 2010 12:21 PM
Lifter / engine tapping... oil pressure issues.. revtor Defender Technical Discussions 10 July 12th, 2007 11:04 PM
TD5 Engine - Parts? Zimbo76 For Sale - Parts 4 October 10th, 2005 11:54 PM
engine oil chart from owners manual Eric_S Defender Technical Discussions 3 November 21st, 2003 10:40 AM
