Defender TD5 throttle failure. - Defender Source
Old July 2nd, 2016, 06:54 AM
defender666
Mark Inker
99 Defender 110
Hi all. I have an early TD5 defender (10P) on which the throttle has stopped responding.
I have already tried a few things as follows:
1, Changed the throttle pedal assembly for a known good one. My original was faulty as proved on another similar Defender.
2, Rewired the pedal using six core sheathed cable.
I have read elsewhere that there should be 7 connections on the pedal but mine only has 6. Pin C going to pin 20 on the ECU is not there.
I have put a Delphi scanner on the car and it is showing an error code 20 - Driver demand 3. It is stuck at 5 volts whereas demand 1 and 2 vary with throttle position.
What is driver demand 3 and where is the sensor.
I hope someone can help, Mark.
defender, td5
Defender throttle pedal assy (1983 through 300tdi) transientmechanic Wanted 14 July 27th, 2013 05:08 PM
td5 3 track throttle pin identification cgalpin Defender Technical Discussions 5 June 20th, 2013 04:43 PM
Oil Line Failure Poll -- Or Did Your Defender Catch Fire Yet? evilfij Defender Technical Discussions 82 July 19th, 2012 05:38 PM
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
D90 throttle pedal assembly and throttle cables Willard For Sale - Parts 2 October 14th, 2008 10:31 AM
