Defender SW Side Window Configurations? - Defender Source
Old November 21st, 2007, 10:43 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
How many diferent SW rear side window configurations are there? I have seen sliders with a riveted on frame and some that do not appear riveted in place. Maybe the rivets are painted black?
What about solid side windows? I have seen what looks like a slider window frame with a fixed single pane glass in it. Was that ever a factory configuration, or just someones own doing?
What did the NAS SW come with?
Gary
Old November 22nd, 2007, 12:44 AM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
SW windows
Hi,
When I put my hardtop together for my ST I want solid windows (no sliders). They are simple, never leak, zero maint and easy to install. NAS station wagons come stock with slider windows. I bought roof sides that had no windows and installed the glass out of a crapped out fiberglass HT and used it for my roof sides and alpine windows. When my truck is in the HT config no one rides in the cargo area - so I really don't need any ventilation back there and if it gets too hot that open windows aren't doing the trick - I turn on the AC. I have attached a couple pics of my HT that shows the details of the glass.
ID:	11126   Click image for larger version
Old November 22nd, 2007, 12:58 AM
The rivets on the sliding station wagon windows are covered by a rubber strip. Sometimes this strip is missing. New station wagons have a new style sliding side window, but I don't think any of those came to the states.
Old November 22nd, 2007, 01:42 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Thanks for the response Len, couple of questions. What color Red is that in your truck, and what seal did you use to install the windows? I have the sliders now, but it is tempting to go to the solid glass instead.
Thanks Jim, that makes sense as I look closer to mine now. I don't have that rubber strip, but will definately get it if I go with the sliders. I don't like the dotted rivet look around the frame...
Gary
Old November 22nd, 2007, 03:33 PM
LenB's Avatar
LenB
Len Bruffett
Seals & color
Hi Gary,
The seals are the same rubber seals used to hold in the alpine windows and rear quarter windows in the roof sides. It is available from Rovers North by the foot. You will also need the rubber spline that expands the channel and hold the window in place. There is a special tool used to install the spline - I don't own this tool - I made a tool to do the job - but it was a hack tool. Contact JimC - he got one and made the job of installing his alpine windows very easy. I think he got it from MCMaster Carr. I don't know the name of the tool but he will. There is no extra sealing materials for the window - you just use a lot of soapy water in a spray bottle to lube the roof sides and rubber to overcome the friction of squeezing the glass into the rubber seals.
My truck is a '97 it is Monza red. When the roof sides were first painted they were much brighter than factory Monza. Hence they look very red in those pics. After a month or so of "dry down" (outgassing) the paint closely matched the color of my truck. I used Dupont Chroma One - it is a single stage paint- it works very well. When some one dinged my right front wing ( they changed lanes into my truck) and I had to replace it, I took my truck down to the shop where I buy my automotive paint and had them "read" the color of my damaged wing. Then when they mixed it, After I sprayed it and it dried down it was a near dead on match to the rest of my truck - . Good luck on what ever you decide to do - don't hesitate to contact me if you need any help. you can always get a hold of me through my americandirtroads.com web site.
Old November 22nd, 2007, 05:33 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Thanks for all the info! My 94 is being repainted Portofino Red as that was the factory color, but I think I like the Monza Red better.
Did you have custom glass cut, or purchase an OE LR piece?
Do you mean a tool like this one?
Gary
Old November 22nd, 2007, 10:54 PM
Nope, a tool like this one:
Its a YA208A from Bluepoint/Snap-on
Old November 23rd, 2007, 12:05 AM
LenB's Avatar
LenB
Len Bruffett
glass
My glass is LR OEM. I bought it used from a guy who could not sell his D 90 fiberglass hard top. It had been cut in half right behind the B pillar roll bar. He couldn't sell it to anyone - so I offered to buy the glass, seals, and all of the hardware. I had to buy the lift gate glass from RN. My lift gate is from a '64 series IIa truck and the glass from the fiberglass lift gate is much bigger than the old lift gate.
window
Need measurements for SW side window placement dave_lucas Defender Technical Discussions 17 May 30th, 2009 05:14 PM
Defender or Series Fold Down Side Steps boshea For Sale - Parts 1 June 17th, 2005 03:57 PM
D90 SW side window trim wanted Chris Cox Wanted 0 January 26th, 2005 05:09 PM
Plastic parts from driver side window?? Vadim Defender Technical Discussions 1 January 18th, 2005 03:06 AM
Soft Top Side Window Bar boshea Wanted 2 June 18th, 2004 08:14 PM
