Defender Stereo and Wiring - Defender Source
Old September 28th, 2014, 11:17 AM
Ferniekids
Piers
1994 NAS 90 ST
I have a 1994 Defender with the original stereo removed. I want to put in a new deck into my Tuffy cubby but would rather not butcher all the wiring. Are there stereos that just plug in to the stock harnesses or do I need a converter. Finally does anyone have a decent stock LR deck resonable that I can just plug in. I want this to be a quick, simple and cheap project.
Old September 28th, 2014, 11:47 AM
You have the wrong vehicle fo quick simple and cheap projects.
Old September 28th, 2014, 12:02 PM
the rover shop
shayne young
There is a good thread already on this.. Use the search function..
Old February 14th, 2015, 05:36 PM
Ferniekids
Piers
1994 NAS 90 ST
Finaly had to go out and buy a new stereo. This will require splicing the wiring. I have searched but not found the wiring diagram for the stock stereo plugs. Can someone point me in the correct direction?
Old February 14th, 2015, 05:58 PM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
So I'm assuming you're not a big stereo music lover if you were originally hoping for a direct replacement to the 20 year old crap that LR originally fit.
It's a simple single din unit that just needs modern circuitry. It's really not that hard but given the 10000's of guys that do just this all day everyday, if you aren't sure just pay someone $50 and get whatever unit satisfies your needs.
1994 Silver DEFENDER 90 NAS SW
Old February 14th, 2015, 05:59 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Full time 12 volt supply, brown wire
switched 12 volt supply, white wire
running lights, red with white tracer
earth black
What more do you need?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old February 14th, 2015, 06:25 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
The basic tape unit that came with mine only get's one station here in North Jersey and that's the new Country station so for right now, I am good...
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old February 14th, 2015, 06:33 PM
Do a search. Many years ago I swapped out my stereo in my 97 Defender and used a VW adaptor plug. It will save you from cutting into your wiring.
Old February 14th, 2015, 08:37 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Metra makes adapter harnesses. Plug and play for the most part.
I actually just put in a brand new Kenwood today for my Rover Project. I don't know why I waited so long, what a massive improvement.
Old February 16th, 2015, 04:59 PM
Ferniekids
Piers
1994 NAS 90 ST
Thanks all. Decided to forgo any adapters and just click her in. No sound yet but I have one wire left from the vehicle, that is, the red wire with black strip which after searching the net is called "light switched".
I also have wire fom the stereo, labelled system remote control. It would not seem logical to attach these two - any ideas?
Finally the antenna has not yet gone up yet, any ideas which power source is likely to do this.
Old February 16th, 2015, 05:24 PM
navydevildoc
Neill Thornton
Thanks all. Decided to forgo any adapters and just click her in. No sound yet but I have one wire left from the vehicle, that is, the red wire with black strip which after searching the net is called "light switched". I also have wire fom the stereo, labelled system remote control. It would not seem logical to attach these two - any ideas? Finally the antenna has not yet gone up yet, any ideas which power source is likely to do this.
Normally the light control wire will go to the illumination input on the stereo.
System remote control could either be the steering wheel controls, or a remote turn in signal for an amplifier. Do you not have the manual for the stereo you are putting in?
Old February 16th, 2015, 05:44 PM
the rover shop
shayne young
Antenna remote wire is usually a blue wire..it gives power when the stereo is turned on and cuts power when turned off..the remote wire will do the same thing..they both have the same functions and one will do for the other.. The light switched wire is wired I to your dash lights wiring.. It will either dim the radio panel when lights are turned on or it will illuminate the panel when lights turned on...
Old February 16th, 2015, 05:52 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Thanks all. Finally the antenna has not yet gone up yet, any ideas which power source is likely to do this.
WAAAIIITTTT a minute...
These antennas are supposed to go up and down with the radio being switched on and off??!!!!
Get outta here!! Seriously????
Attributed to Shayne...
Old February 16th, 2015, 06:03 PM
the rover shop
shayne young
Only if you've got an electric one..
Old February 16th, 2015, 06:17 PM
kevincdoyle
Kevin C. Doyle
Well, they didn't come like that from factory I'm assuming. Not even an option?
Had me worried for a sec...
defender, stereo, wiring
Stereo Wiring TDI Guy Defender Technical Discussions 12 September 27th, 2010 12:49 PM
Switch/Wiring Question: Stereo Ignition Power Override nimbusnic Defender Technical Discussions 3 June 30th, 2008 01:05 AM
Stereo Wiring Questions gtg067i Defender Technical Discussions 1 June 19th, 2005 08:10 PM
Stereo Wiring Harness Manufacturer? priest944 Defender Technical Discussions 7 January 11th, 2005 06:03 PM
D110 Stereo wiring pcarey Defender Technical Discussions 1 November 23rd, 2003 10:57 PM
