Defender Steering Drop Arm - Removal - Defender Source
Old September 4th, 2013, 03:52 AM
SpitfireTDI
James
300 TDI 1996
Hi guys,
I've been told that my power steering box is leaking on my 90. And that I need to change the seal. Problem being I've undone the big nut below the powersteering box holding the drop arm on. But it won't shift!
Apparently this is a nightmare of a job?? Can anyone give me an insight as to how to get the drop arm off without damaging the splines on the power steering box???
James
Old September 4th, 2013, 06:36 AM
myoverlandrover's Avatar
myoverlandrover
josh
109
Steering arm puller
http://m.autozone.com/autozone-mobil...264w?id=555631
Defender 110
Old September 4th, 2013, 07:23 AM
SpitfireTDI
James
300 TDI 1996
Thanks. I'll take a look.
I've also found this..
Any one used one?
http://www.hnjengineering.co.uk/page...nj7000000.html
Old September 4th, 2013, 07:51 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Originally Posted by myoverlandrover View Post
I have this one as well and have done a few drop arms with little difficulty.
Old September 4th, 2013, 08:18 AM
Howski's Avatar
Howski
Kevin
2002 Land Rover Discovery II
I used a pitman arm puller, then heated it up and still no luck after a day of hammering on it. I actually ended up being the puller because the arm was so stubborn. If it's really giving you a problem remove the steering box and take it to a machine shop to be pressed off. That's what I ended up doing and wish I'd done it to begin with.
Whats in my container??????? SafariHP The Vendors Loft 30 November 26th, 2015 07:31 AM
Steering Drop arm D-90 special brn24whl The Vendors Loft 4 September 15th, 2011 02:39 PM
More Steering Box Questions kzack Defender Technical Discussions 6 May 5th, 2011 12:51 PM
Pitman arm to Steering box question dmarchand Defender Technical Discussions 3 September 5th, 2008 11:53 PM
Drag link end @ steering drop arm Uncle Douglas Wanted 3 August 10th, 2008 11:14 PM
