Defender relay install - Defender Source
Old May 4th, 2016, 07:43 PM
ckg
Chander G.
1993 D110
I'm installing a headlight relay and have a question...
There seems to be a terminal block under the drivers seat (see pic). Can I use that as the positive and negative terminals (instead of hooking directly to the battery?). Also, the power cut off switch seems to do so by isolating ground from the battery. But the negative on that same terminal block is hooked directly to the battery - so does it bypass the cut off?
Thanks!
Old May 4th, 2016, 07:52 PM
Nos4ra2's Avatar
Nos4ra2
Nos4ra2
1995 NAS D90 #2489
off topic,
is your 110 painted black?
------ Follow up post added May 4th, 2016 05:53 PM ------
owner of a black 110
Old May 4th, 2016, 07:56 PM
ckg
Chander G.
1993 D110
Originally Posted by Nos4ra2 View Post
off topic,
No. But there is some spray paint there I think.
Old May 7th, 2016, 02:03 PM
ckg
Chander G.
1993 D110
Okay, so if someone comes in later and sees this thread. those posts are apparently split charge wiring posts, with the positive being hooked up to a 60A(?) relay under the hood which can be used to charge a second battery; it only gets power when the engine is running. It's powered by the alternator (so only gets power when the engine is running, not JUST the ignition switch being on.)
I'm considering hooking my relay/lights to this, which ought to (I think :-) ) take care of making the lights shut off when the engine shuts off. It's a little lower-tech than connecting to the ignition relay, but also supports higher amounts of current - which I'm not sure the ignition relay would handle anyways (esp if I put in higher current lights.)
defender, relay
Defender flasher relay prc8876 Ben01 For Sale - Parts 2 April 7th, 2014 07:08 PM
Battery relay for dual battery install plus cables jonathon For Sale - Parts 1 February 3rd, 2014 07:36 AM
Fuel pump relay 95 D90SW alaskajgg Defender Technical Discussions 32 September 18th, 2006 10:26 AM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
Electrical relay issues???? PMHAH Defender Technical Discussions 1 November 20th, 2003 02:32 PM
