Defender pressurizing the cooling system - Defender Source
Old April 4th, 2006, 08:44 PM
DesertRat
Bryan Barnes
95 D90 2.8TGV
Recently my Defender started overheating and losing coolant. Signs pointed to a blown head gasket or cracked head. I tore the engine down (enough to remove the heads anyway) and took them to the shop to be checked and reworked if they were ok. They were rebuilt and ground flat as there was a little warp(.05mm). Ordered all the gaskets and put everything back together.
Good news is that it runs fine. Bad news is it's pressurizing the cooling system somehow. With the cap off there's a lot of "agitation" in the coolant. With the cap on the top radiator hose gets rock hard before it comes close to getting hot. Any ideas of what could be causing this? I was meticulous about documenting how everything came apart but now I'm thinking maybe I did something wrong? Any help would be greatly appreciated. Thanks
Bryan Barnes
95 Defender
Old April 4th, 2006, 08:47 PM
maybe something is clogged up
Old April 4th, 2006, 09:19 PM
robisonservice
John Robison
2008 Supercharged Range Rover
You may have a liner problem, or you may have a warped deck surface on the block. Or you may have missed a problem with the heds or made an assembly error. I have a new article on dropped liners on page 12, here:
http://catalog.roversnorth.com/downl...36_RN_News.pdf
Old April 5th, 2006, 08:11 PM
DesertRat
Bryan Barnes
95 D90 2.8TGV
Thanks.
Thanks to all who responded. Confirms my fears. Looks like it's time to do more than just talk about converting to diesel.
Old April 6th, 2006, 01:08 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Before you give up hope, see this thread--worked for me.
http://www.defendersource.com/forum/...cylinder+glass
Defender cooling fans with clutches pendy For Sale - Parts 2 January 15th, 2006 11:47 PM
Cooling system pressure Antonios Defender Technical Discussions 15 November 1st, 2005 01:33 PM
Defender AC system for sale draaronr For Sale - Parts 12 June 9th, 2005 08:47 PM
Who wants to sell their Defender AC system draaronr Wanted 12 April 9th, 2005 08:35 PM
cooling system rover4x4 Defender Technical Discussions 1 October 21st, 2004 02:02 PM
