Defender plastic tank insulation pads location? - Defender Source
Old July 8th, 2017, 12:26 PM
RFD110's Avatar
RFD110
Rob Dennis
D90, D90, D110
I am installing a plastic tank on a new frame, and received the tank and all hardware from RN. Included were 4 insulation pads MXC5714. About 2" in diameter and 3/4"thick. I see them on the parts diagram, but have no idea where they go. I have another chassis that has a factory plastic tank and can't locate it on that one either. Anyone know where these go?
Old July 8th, 2017, 03:53 PM
RFD110's Avatar
RFD110
Rob Dennis
D90, D90, D110
This is on a 110. Micro Cat says 2 for a 90, 4 on a 110 out 130. They are also probably a little over 3" in diameter(not 2"). There is a 3/8" hole in the center and adhesive on one side.
Old July 8th, 2017, 04:11 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
If I recall correctly, my Td5 plastic tank had 4 round areas, on the top of the tank, where these thing were glued
Old July 8th, 2017, 08:17 PM
RFD110's Avatar
RFD110
Rob Dennis
D90, D90, D110
I went back and looked and there aren't any such spots on this fuel tank. I guess I'll have to wait and call RN on Monday
Old July 10th, 2017, 12:59 PM
HGR
1987 110 TD
seem to remember that these went on the sides of the tank, between the tank and the chassis to snug up the fit.
Old July 10th, 2017, 10:01 PM
RFD110's Avatar
RFD110
Rob Dennis
D90, D90, D110
Rovers North says they think they go on the bottom.(They weren't very convincing). I'll look on the sides again as well. Looking at the one factory plastic tank I have access to, I can't really see how they'd be on the bottom, unless they've been completely flattened.
Sent from my iPad using Tapatalk
Old July 10th, 2017, 10:49 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I've had my tank off several times.
Those pads go on the sides where the tank would bump the chassis on the sides.
They get glued on the sides of the tank.
Old July 10th, 2017, 10:50 PM
RFD110's Avatar
RFD110
Rob Dennis
D90, D90, D110
Those pads go on the sides where the take would bump the chassis on the sides.
Thanks!
defender, pads
Plastic 110 tank BlackField Wanted 7 September 3rd, 2013 08:20 PM
Slickrock Defender 90 Sliders dave_lucas Vendors 15 November 28th, 2010 03:45 PM
Really? Plastic Defender parts? Really? Roving Beetle Misc. Chit-Chat 12 October 6th, 2010 08:02 PM
Defender OEM Aux tank info Overlander Defender Technical Discussions 16 August 5th, 2010 09:38 PM
Defender 200tdi wastegate / boost tee location dave_lucas Defender Technical Discussions 9 November 18th, 2009 03:18 PM
