defender pitman arm on disco 1 box? - Defender Source
Old August 30th, 2016, 09:37 PM
buck toenges
fred toenges
1986 110 tithonus
Can anybody tell me if the defender 110 tith pitman arm fits on a disco 1 ps steering box? I am gathering parts for a power steering upgrade. I am looking for an easy conversion of a ps steering box for my 110 tith.
Buck
Old August 30th, 2016, 09:52 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Yes, the pitman arms are interchangeable. I advise running the Disco arm and longer draglink as the tie rod end is much easier to replace than the ball joint that mounts into the Defender pitman arm. It also allows for more suspension travel.
-Ash
Geared Restoration Co.
352-572-3236
Old August 30th, 2016, 09:54 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Not sure about Tithonus, but regular defender pitman arms fit just fine. I would actually recommend keeping the D1 pitman arm and converting to d1 steering rod ends... Just my opinion, I do it on most of my trucks!
Old August 30th, 2016, 10:00 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Works great. That's my setup.
Old August 30th, 2016, 10:03 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
As mentioned above, the D1 tie rod set up is better, but get an aftermarket dampner kit to mount it in the defender location. The D1/RRC dampner location is horrible.
and this!
Old August 30th, 2016, 10:11 PM
another vote for the disco setup. We replace the defender setup on nearly every truck
Old August 30th, 2016, 10:41 PM
It's not that bad if the pitman arm ball joint is good.
Old September 14th, 2016, 09:01 PM
buck toenges
fred toenges
1986 110 tithonus
starting to put the power steering bracket on tith
I am starting to get ready to put in a power steering set up in my 1986 tith. I was under the truck tonight to see how the bracket fit on the engine. There doesn't seem to be enough room for the bracket under the alternator bracket. From what I can tell the bracket is held onto the engine by 2 bolts. Is the bracket bolted to anything else? Does the alternator bracket bolt to the power steering bracket
http://www.defendersource.com/forum/...p;d=1383437155
defender, disco
Defender pitman arm Oliver Whiting For Sale - Parts 1 June 13th, 2014 01:41 AM
Wanted: d-90 pitman arm, Defender Cross Rod End Blakesrover Wanted 6 September 25th, 2009 08:38 PM
Pitman arm to Steering box question dmarchand Defender Technical Discussions 3 September 5th, 2008 11:53 PM
Steering box shaft movement after tightening pitman arm nut Neil McCauley Defender Technical Discussions 18 June 10th, 2008 02:18 PM
little piece that steering damper mounts to near pitman arm evilfij Wanted 4 October 5th, 2004 08:55 PM
