Defender parking brake upgrade question - Defender Source
Old August 6th, 2009, 03:53 AM
I have read in a UK forum I believe somewhere about a common upgrade for Defender parking brake to DII parking brakes. What's that all about? After Dendy's near disaster, got me thinking. Being in Iraq, I have a lot of time to think.
Old August 6th, 2009, 06:17 AM
I think it is just the cable. Someone did it here. I used a DII parking brake cable for my LT230 swap. I think it just has more heat shielding.
Old August 6th, 2009, 08:11 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Do you mean the disk brake conversion? the DII has more or less the same setup as the earlier rovers (drum brake), but the X-Eng disc brake conversion could be what you're after.
I've got one on my 110, excellent piece of kit. yeah, possible to make one up yourself, but it's cheap enough not to bother with the hassle!
Old August 6th, 2009, 10:21 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Lucky8 is importing the X-Engineering stuff now.
Old August 6th, 2009, 10:30 AM
good to know, thanks! Xbrake looks like the solution
Old August 6th, 2009, 10:36 AM
Abrooks's Avatar
Abrooks
Tony Brooks
I installed a D2 brake on the 110 when I did the transfercase swap -- difference is really in the cable as the cable (as well as the brake) is adjustable. You'll need to swap over the brake assembly to do so.
brake
Parking Brake Abrooks Defender Technical Discussions 15 September 23rd, 2011 09:57 PM
parking brake switch Campbell Defender Technical Discussions 6 September 20th, 2005 08:45 PM
Brake Light Question waveridin1959 Defender Technical Discussions 6 May 4th, 2005 02:42 AM
Parking brake light howellm70 Defender Technical Discussions 4 September 27th, 2004 02:19 PM
Brake upgrade Defender50th Defender Technical Discussions 2 September 26th, 2004 04:21 AM
