Defender Oil change for a noob - Defender Source
Old March 16th, 2013, 04:36 PM
jamonhemingway
jamon
1997 defender 90
I've searched for a few minutes but couldn't find the answer. How much oil does a 97 NAS defender take and what is the weight that is recommended? It has 60,000 miles on it. I found one post that said 10/40 but i couldn't see how much the engine needs.
Old March 16th, 2013, 05:38 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Six quarts will do the trick. Always fill the filter before putting it on.
Any mention of oil brand and/or weight will yield a multitude of opinions. I use 15/40 Rotella T.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old March 16th, 2013, 10:50 PM
jamonhemingway
jamon
1997 defender 90
Thanks for your help
Old March 16th, 2013, 11:19 PM
Pick up a can or two of engine cleaner when you get the oil. IIRC, when you remove the drain plug oil gets all over the exhaust and a few other things. Some guys use a 1 1/2" PVC pipe and elbow as a deflector.
I wish LR would have come up with a better place for the sump plug and filter. I can change the oil in my FJ Cruiser in a tuxedo in less than 5 minutes and stay 100% clean. The oil comes straight down into the pan, nothing for it to splash onto.
The filter has a funnel around the bottom that drains into a small pipe. I stick an empty water bottle under it to catch any oil drippings.
Old March 17th, 2013, 08:24 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
If you're a noob, here are the steps.
1. Get drain pan, place under drain plug on engine sump.
2. Loosen drain plug with a wrench (note: righty tighty lefty loosey)
3. Remove drain plug from oil pan.
4. Curse loudly because hot oil just ran up your arm and spewed all over the ground, splashing off the catalytic converter.
5. Wipe off hands with rag, being careful to not rip off the bits of skin torn loose when the wrench slipped in step 1.
6. Pour oil absorbant (stolen from cat litter bag when your wife isn't looking) on spilled oil.
7. Check if oil is finished draining.
8. Quickly slide pan back under drain plug, to catch the last bit, from where you shoved it when the oil first overshot the pan.
9. Put more cat litter down.
10. Replace drain plug.
11. Tighten
12. Remove drain plug again because you realize you forgot the copper washer.
13. Fish around in hot oil in the bottom of the pan for the washer.
14. Replace washer, replace drain plug.
15. Remove filter
16. Go in garage to look for filter wrench because you can't perform step 15
17. Go ask wife to go to autoparts store for filter wrench because you can't find yours and you're too oily to drive, and you don't want her seeing the cat litter stuck to your back.
18. Have a beer while you wait for your wife to come back.
19. Realize you don't have any oil.
20. Frantically call your wife's cell.
21. Go get ice to put on your foot you hurt kicking the Rover's wheel when you heard your wife's cell ringing in the kitchen.
22. Think of other option and quickly grab phone book, look up parts store number and dial frantically.
23. Put down the phone and rush outside when you hear your wife drive up, trying to act nonchalant when you ask her to turn around and go back for oil.
24. Ignore her rolling eyes as you carefully specify the exact brand and weight you want, giving her several other choices in case they are out of what you want, plus other stores to check.
25. Have a beer while you wait for your wife to come back.
26. Ignore the fact when she returns that she bought the store brand oil.
27. Remove the filter.
28. Use your daughters bike, yes, the one with the tassles on the grips, to bike to the store for an oil filter because you know better than to ask your wife to go again.
29. Have a beer when you get home to console yourself from the strange looks you got at the parts store.
30. Install new filter.
31. Add new oil.
32. Frantically replace drain plug because you missed step 14 because you couldn't be bothered to read the instructions. After all, you are a man.
31. Dump more cat litter on the ground since you'd moved the drain pain when looking for the washer.
32. Get owners manual because you've no idea how much oil it takes.
33. Try to wipe the oil smudges off the manual's pages.
34. Replace the oil filler cap, put tools away (hanging up filter wrench so you can find it next time).
35. Tell yourself you'll get it later when it falls off the hook and lands behind a cabinet, in spite of the fact you looked behind it and saw two filter wrenches.
36. Wipe the oil off your hands and go get a beer.
37. Try your best to look innocent as you hear your wife cursing the cat for tracking cat litter all over the house.
38. Sleep on sofa because your wife noticed the cat litter still stuck to your back.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 10th, 2013, 07:09 PM
jijalicious
Jiman Khosravan
'94 D90
That is COMIC GOLD.
Old April 10th, 2013, 07:44 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Where were you when I first got into 90's? I see technical writing in your future! Photos would have been nice...as you point out he/we are men and fail to read (all of) the steps...lol.
Old April 10th, 2013, 08:40 PM
The Dro
Dro
1988 Ninety
11. Tighten
15. Remove filter
31. Add new oil.
I bet this happens every 5,000 miles. LMAO
Good one
Oil and an ARB compressor amasaback Defender Technical Discussions 12 April 4th, 2006 02:22 PM
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
Defender Noob KWmisfit Defender Technical Discussions 11 April 4th, 2005 06:21 PM
How and Why to add an oil thermostat Hans Misc. Chit-Chat 0 February 18th, 2005 03:57 PM
OIL...oil...oil... norros Defender Technical Discussions 20 August 22nd, 2004 01:30 AM
