Defender not wanting to start in below freezing weather - Defender Source
Old December 7th, 2013, 11:59 AM
Korongo's Avatar
Korongo
Cameron Bell
1984 Defender 90, 1988 Defender 110
I have a 2.5na and it doesn't want to start. I'm guessing it's the freeze we're in but thought I'd check to see if this is normal? It started to turn over but sounded like there wasn't enough power from the battery, like it was turning in slow motion. It was 18 degrees and I've never tried to start it when it was that cold... I live in Texas. Thanks
Old December 7th, 2013, 12:07 PM
Batteries don't like cold and your battery may also be on its way out. Try charging it for an hour or so and try it a again. Charging obviously adds power to the battery but it also warms it up.
Old December 7th, 2013, 12:08 PM
Sounds like you need a better battery. Give it a lot of glow. 30 to 60 seconds before starting. I've started mine at -30.
Old December 7th, 2013, 12:47 PM
Korongo's Avatar
Korongo
Cameron Bell
Thanks, I gave it plenty of glow... I'll charge it up and see!
Old December 8th, 2013, 01:55 AM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
I've never gotten a 2.5na to start much below -20c, sometimes not even that cold. However, they usually turn over but just don't catch. If it isn't turning over much it is likely the battery. The 200tdi seems to be a much better cold starter.
Old December 8th, 2013, 02:18 AM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
I leave a 60 watt drop light neslted above the injector pump when mine is in the garage. 30 seconds of glow and she cranks right up down to 15f.
X2 on the battery.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old December 8th, 2013, 03:45 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Any diesel can be harder to start in the sub freezing weather. A strong battery is a must. If the motor sits for a few days in that cold even worse. A Engine block or oil pan heater are great. They also make engine blankets. But as mentioned a heat lamp helps. They also make low watt electric heaters for home waterlines that could be used.
defender, start
Whats in my container??????? SafariHP The Vendors Loft 30 November 26th, 2015 07:31 AM
94 Defender 90 cranks but won't start Charles LF Defender Technical Discussions 6 September 9th, 2009 02:43 PM
2007 Defender details announced Kev Baldwin Misc. Chit-Chat 17 August 22nd, 2006 09:01 PM
Defender 90 Scoop For Sale - Vehicles 0 December 10th, 2005 11:46 PM
Ignition Relocation = No Start...Help JRowe Defender Technical Discussions 5 March 8th, 2004 12:45 PM
