Defender mechanic in Central America? - Defender Source
Old August 16th, 2011, 12:22 PM
nopants
Joe
1985 Defender 110
Anyone know of a good mechanic in southern central america? Panama preferably, but Nicaragua and Costa Rica also work.
I need a starter in my 200tdi and pinion seal in the Sals rear end.
Old August 16th, 2011, 12:58 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I dont know of one, but both of those jobs are really easy. Starter is 2 or 3 bolts and a plug, and the pinion seal takes 20 min. If you want more info say the word.
Look for National Seal 9316 for the pinion... way better than stock. it is for the dana 60 axle.
Tuff part is getting a starter down there.... if you cant find local... ask Rovers down south.
Old August 16th, 2011, 01:11 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
You might find help here: <http://geocities.com/baja/trails/9191/>
John Karlsson
Hope Valley, RI
Old August 16th, 2011, 02:36 PM
Shawn's Avatar
Shawn
shawn Orth
1994 Defender 90
http://costarica.en.craigslist.org/pts/2527964155.html
try these guys. they are in San Jose I think. Shawn
Old August 17th, 2011, 12:28 AM
nopants
Joe
1985 Defender 110
I havent even looked at either job. I was expecting the worse. I had to change a starter in a D1 a while ago and it wasn't too much fun, especially if I had to do it on the road with crappy tools and no lift.
I am hoping to have a starter shipped into Panama. If they are both easy jobs I will certainly do them myself. I hate paying someone else to do the work if I don't have to.
If you have the info on the work, that would be great, but if it is only a few bolts, that should be easy enough for me to figure out. Ill get a light and take a look under the hood tomorrow.
Old August 17th, 2011, 08:42 AM
carlosz's Avatar
carlosz
Carlos
you can have the starter overhauled there, it may be easier and more economical than ordering and waiting for the proper unit.
as per the seal I dont know people down south of dc...
good luck.
Old August 17th, 2011, 10:18 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
There is a guy on ADVRIDER that goes by the name of Bananaman, he has a Defender in Panama and might be able to recommend a mechanic.
I'll send him a PM and see if he knows anyone.
Just sent him a PM, let's see what he responds.
John C.
Old August 17th, 2011, 11:09 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
If I remember well we have someone on the
board from Panama city.
There are a few part store and workshops
in San JosÚ, I know 2 at least.
- Charles Eames
Old August 18th, 2011, 12:40 AM
nopants
Joe
1985 Defender 110
Well, we probably wont need a mechanic in Panama anymore. Our transmission crapped out in Managua Nicaragua. I will take care of the other problems while we are down waiting for the tranny parts. So far the starter has been working well. Occasionally does a single click on the first key turn but always starts up on the second try. The pinion seal is leaking still and goes through a quart every couple thousand miles. Not great, but manageable.
Full story and some pictures for those that are interested here:
www.time2getlost.com
Old August 18th, 2011, 08:30 AM
Have you changed a starter on a 200TDI Defender? If it is LHD, it is a horrible job. The exhaust downpipe has to come off and even then you can't see what you are doing.
Old August 19th, 2011, 05:15 PM
nopants
Joe
1985 Defender 110
Toasted at least one bearing. Waiting for the full report still. Gears looked ok from what I saw.
http://www.exploringnh.com/images/Us...Managua003.jpg
Full photos and more words:
http://time2getlost.com/
What does it take to be able to post pictures here?
Old August 19th, 2011, 06:02 PM
defeyago's Avatar
defeyago
Santiago
┤96 Defender 110 VGTdi SW County
That┤s probably just the nut that holds the wire that comes from the battery to the starter a little bit loose. Thighten the nut a little bit and the "click" will dissapear for ever. I┤d try that first before taking the starter out.
Cheers,
SANTIAGO
┤97 Defender 110 Tdi SW
┤04 Freelander Td4 5 dr.
┤97 Alfa Romeo 146 TD (Sold)
┤95 Volvo 850 GLT Estate
┤94 Discovery Tdi (Webasto equipped)
Old August 19th, 2011, 09:01 PM
JohnC
Click on Manage Attachments
ID:	41246   Click image for larger version
John C.
Old August 20th, 2011, 12:02 AM
nopants
Joe
1985 Defender 110
No inline images then? Just attachments?
edit:
http://www.exploringnh.com/images/Us...hCreek006.jpg:
Upload failed due to failure writing temporary file.
Old August 22nd, 2011, 01:17 PM
JohnC
edit:
http://www.exploringnh.com/images/Us...chCreek006.jpg
You have a colon after jpg
John C.
Old August 22nd, 2011, 11:20 PM
nopants
Joe
1985 Defender 110
I guess that is what I get for trying to do stuff late at night after a long day of riding/driving. Thanks.
Old August 26th, 2011, 07:59 AM
JohnC
I just got a response, sorry if it's too late:
Sorry I didn't notice this message.
There's a decent LR mechanico in the old Canal Zone. Go North along the RR track, on the West side of the RR track, until you come to the old crane on the left. The LR mechanic is on the north end of that old base.
This is just north of Albrook/Gelalbert, by the El Rey.
John C.
Old August 26th, 2011, 09:25 AM
nopants
Joe
1985 Defender 110
Too late for the first rebuild, but not for the second!
We pulled an all nighter to get away from Managua, Nicaragua. Our newly rebuilt transmission was doing fine until the very end of Costa Rica. We were cruising along in 5th gear, no real load on the transmission, pretty flat ground and all of a sudden there is a clank and it feels like this shifter popped out of gear, but it was accompanied by a lot of rattling type sounds. Downshifted to 4th and I was surprised that it was still there. We continued on in 4th for several miles until we had a chance to test out the other gears. 4th is the only gear that works. No reverse, 1st, 2nd, 3rd, or 5th. We plan our stops for the tops of big hills and pray that we don't hit traffic. Luckily 4-lo works so we can use that in town for speeds up to 25mph, but we can't shift from 4-lo to 4-hi on the fly.
We are in Panama City and have contacted someone here who may have a spare transmission. I am thinking about putting an R380 into it now, since I have to pay to have the LT77 rebuilt again anyway.
I just tried uploading again and I get the same error when uploading from a URL. I can attach from my computer just fine. The link I used above (and now) didn't have a colon at the end. The error screen adds that colon when it displays the message.
Old August 26th, 2011, 10:52 PM
nopants
Joe
1985 Defender 110
Unnecessary post. Can't delete.
Old August 29th, 2011, 04:45 PM
defeyago's Avatar
defeyago
Santiago
Cheers,
Did you check this?
If you need any help once you are here in Argentina just let me know. Have a good trip.
Cheers,
SANTIAGO
central america
94 NAS Defender 90-P.O.E.(Port of Entry) 1 of 65 made! on EBAY SeanD-90 Misc. Chit-Chat 29 May 27th, 2017 08:14 AM
Defender Mechanic near Stamford, CT geoellis Wanted 8 February 6th, 2011 11:18 PM
NLX & OT Central America Part 2 JPBrown The Vendors Loft 4 September 24th, 2010 06:01 PM
No Limit Expeditions - Central America Scout Trip JPBrown The Vendors Loft 18 June 12th, 2010 04:49 PM
Defender Returns to North America Merged Threadfest rover1 Misc. Chit-Chat 495 May 12th, 2010 11:32 AM
