Defender laptop mounting? - Defender Source
Old May 6th, 2009, 07:20 PM
tommyd's Avatar
tommyd
Tom
LR3
Trying to decide on the best mounting system for a laptop in my 110. Any of you guys have pics of your setups I could see?
Thinking of a RAM mount:
https://www.expressmounts.com/item-r...am316-3101.htm
or maybe a Jotto:
http://www.jottodesk.net/
any advice is greatly appreciated.
Tom
Old May 6th, 2009, 10:26 PM
you going to spend that much time in the 110 Tommy ?
Old May 6th, 2009, 11:12 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
I have a RAM mount inbound. Will post up when I get a chance to install and assess. Mark
Old May 7th, 2009, 12:07 AM
tommyd's Avatar
tommyd
Tom
LR3
I hope so!
I want to use Overland Navigator on my tablet PC:
http://spatialminds.com/Overland-Nav...B001TM05D0.htm
cool, thanks Mark. How about seeing some pics of your Td5 110 while we're at it?
Old May 7th, 2009, 08:26 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
I installed a RAM mount for my tablet PC in my 110. I used the three legged universal mount and secured it with the existing bolts on the side of the tranny tunnel and one on the seat base. It hampers the passenger's leg room a little so I take the mount tray off when I am not using it. This setup works a bit better with a laptop than a tablet due to the angle of the tray being somewhat flat. It is stable though.
Old May 7th, 2009, 09:12 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I have a jotto. I hard mounted a base between the passenger seat and the tunnel. The extension plugs into the base and I made a different cradle for the laptop. Very stable, adjustable and removable. Only small base bracket remains in vehicle. I'll try to post pics tomorrow
Old May 7th, 2009, 10:19 AM
I'm interested in seeing your setups for this.
Do any of these setups have a way of swinging the tablet/laptop into a position that doesn't take up much space when not in use?
For now I just made a simple little bracket that slips onto the dash pad and uses a single screw in an existing hole (the ashtray) so it's easy to swap between trucks. It actually works so well all I think all I'll do on the final version is angle it slightly toward the driver.
Old May 7th, 2009, 10:40 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I use the jotto. Like it but if you have a passenger, it takes up too much room.
Old May 7th, 2009, 10:53 AM
61rover's Avatar
61rover
John Crouse
Laptops
http://www.gamberjohnson.com/
I've installed hundreds of these in every vehicle imaginable. Highly recommend.
Old May 7th, 2009, 11:30 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Mine is located where it doesn't interfer with the passenger(on seatbox not on floor) and can be has an adjustable arm so I position it almost anywhere I want
Old May 7th, 2009, 11:56 AM
Ray_G's Avatar
Ray_G
Ray Gerber
I had a kodiak docking station for my Toughbook CF-28 in my Disco-it was something that could be moved both up and down as well as swing along a radius as well. I put it in between the seats behind them so that the passenger would have room-and ultimately be responsible for manipulation of the computer (vice the driver).
The mount was essentially what you see in police cars, and the CF-28 could be locked into it, so it was very stable and rather secure. My long term intent was to run a smaller touchscreen up to the dash so that navigation could be displayed through that. Instead I ended up getting a tablet that I'll just mount direct to the dash via a ram mount and will be going with the same nav software described above.
I'll post pics of what I did when I get back to my home computer tonight-the behind the seat's mount worked well for me since I almost always have a passenger and I didn't want to have them bumping into the computer/docking station etc.
r-
Ray
Old May 7th, 2009, 12:03 PM
landrovered
S. Smith
I have been flirting with a dedicated car computer with a 7" or 8" touchscreen. They are getting to be badass with constant ODBII monitoring of engine functions in addition to nav, music, internet, video etc.
Old May 7th, 2009, 03:37 PM
tommyd's Avatar
tommyd
Tom
LR3
Thanks for everybody's replies. Any pictures would be great. I want to figure out a way to mount it so that my passenger doesn't lose too much legroom or have the laptop/mount in their way when not in use. Maybe a dash mount, but I'm not sure how I'd make that work...
Old May 7th, 2009, 09:08 PM
DonFromWhitby
Don Andrews
'94 NAS D90 #CDN-80, 2011 LR4
If you find one that does that, let me know! I'd love to do something similar.. I'm pretty sure my D90 is causing some oil shortages around here, as the gas prices seem to go up whenever I take it out of the driveway. I'm averaging 280km's per tank!
Old May 8th, 2009, 08:27 AM
landrovered
S. Smith
Here is a link to the ODBII software, look around this site they have some great ideas on car computers.
http://store.mp3car.com/ScanMaster_O..._p/sof-scm.htm
Old May 8th, 2009, 08:39 AM
This stuff all exists, and most of it for free even. For obdii monitoring for example
http://www.mp3car.com/vbulletin/engi...lets-talk.html
Whoops, looks like Scott beat me to it. mp3car is probably the best resource for this kind of stuff but google is your friend too.
Old May 8th, 2009, 08:57 PM
Ray_G's Avatar
Ray_G
Ray Gerber
As a follow up, here's a pick of my setup in the truck, I know it's not the style of application it would seem you're looking for but a pic is a pic so I thought it worth putting in the thread just as food for thought.
r-
Ray
Name:	Toughbook3 (Medium).JPG
Old May 9th, 2009, 02:45 PM
I was a beta tester for Overland Navigator and can comment on any questions you might have.
mount
94 NAS Defender 90-P.O.E.(Port of Entry) 1 of 65 made! on EBAY SeanD-90 Misc. Chit-Chat 29 May 27th, 2017 08:14 AM
Whats in my container??????? SafariHP The Vendors Loft 30 November 26th, 2015 07:31 AM
defender 300tdi air cleaner mounting Ren Ching Defender Technical Discussions 15 November 20th, 2012 11:03 AM
200tdi air filter mounting bracket (defender) dave_lucas Wanted 2 December 4th, 2009 08:26 PM
