Having problems with the hood not popping up when I pull the release, somtimes it does..sometimes not. Greased up the release mechanism, checked the spring on the hood..no idea if i should mess with that, I see theres a lock nut and the possiblilty to turn the shaft but..compress the spring??
I had the same problem when I bought my D90. I took the spring mechanism off and cleaned the gunk of of it and lubed it. Then made sure the pin went into the latch on center so the side of the pin was not contacting the latch plate. Finally, make sure your release cable is pulling the latch open enough to fully release the post. Good luck.
Not a fan of grease as it catches dirt, turning into a nasty paste.
Clear all the gunk off the catch with copious amounts of silicon spray( confess I accidentally used brake cleaner last time) them when clean use silicon lubricanting spray
99% of the time this is more an alignment problem than a lubrication problem. Ensure the pin is completely centered in the latch. Do not attempt to use the pin to align the hood (people actually do this and then wonder why the hood won't open). Also, ensure the hood level adjusters on each side of the latch are properly adjusted.
If you never removed the hood and/or messed with any other parts mentioned above and the problem just appeared and cleaning/lubrication doesn't help, your release cable may be too worn/stretched and corroded/gunked up inside. Get a new one - they're cheap and relatively easy to replace.
According to the VIN it was originally a right hand drive 110, the previous owner said he had it converted around 2003 so Im guessing the whole front end was apart thus the hood not working right
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
