Defender high steer setup? - Defender Source
Old January 8th, 2016, 01:57 AM
NSGINC's Avatar
NSGINC
Nathan Garnand
74 Series 88
Hello, I am about to swap defender axles into my leaf sprung series 3. Anyone know of a high steer setup? Or have any suggestions on making one.
Thank you.
Old January 8th, 2016, 02:48 AM
Departing90
Sasha
95 D90
You can use a P38 steering box / P38 modified drag link / discovery I PS pump & fluid reservoir / 1 custom high preasure hose & a double V pulley for a power steering setup. In addition you would need to fabricate 1 bracket for the PS pump and another for mounting the steering box to the frame. I dont have plans for the brackets but made several from a template last month when doing this conversion if your interested.
Old January 8th, 2016, 07:16 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
I did a hi steer on my 109. Axles, of course, are different front the defender so I'm not sure if my setup would be helpful. I had some arms made to bolt to the top of the swivel housings. I made drag link and tie rod out of some stout tubing with one ton tie rod ends to fit the arms.
Old January 8th, 2016, 07:04 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Are you doing SOA or SUA set-up?
Old January 8th, 2016, 09:39 PM
NSGINC's Avatar
NSGINC
Nathan Garnand
74 Series 88
Departing 90, power steering is on the things to do list. I would like to someday take you up on your offer. Thank you.
Slorocco do you have any pictures of your setup?
Roverchef I am spring under axle setup.
I picked up a set of complete defender axles with air lockers for a fare price. So I will be installing them as soon as I figure out a high steer setup. I am thinking of getting a swivel housing off a right hand drive defender or disco. I will post in the wanted section asking for one. Maybe I will get lucky.
WTT 1987 90 SW setup for ST setup javelinadave For Sale - Parts 0 July 19th, 2013 12:09 PM
Nas steer wheel wantone For Sale - Parts 2 May 12th, 2010 09:52 PM
F/S Hi Steer setup pushngo For Sale - Parts 0 June 17th, 2009 02:53 PM
Torque Steer - LSD CDeWan Defender Technical Discussions 1 April 11th, 2009 02:07 AM
anyone have draken steer. guard with ARB? needsaD110 Misc. Chit-Chat 2 November 14th, 2006 09:36 PM
