Defender Exterior Mirrors and my troubles - Defender Source
Old March 11th, 2009, 02:42 PM
Overland90's Avatar
Overland90
95/D90 #169; Aston Martin
Stupid problem...
Once the speedometer hits 65, the mirrors start flappin' like "ailerons" on a Cesna Skycatcher
I replaced the originals with spiffy new ones...same air foil trouble.
Outside of staying below 65, is there a solution that won't impact the beauty and stealth of the D90?
Old March 11th, 2009, 04:04 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
What is the source of the flapping? Is it the mirror head or the arm (screwed into the hinge)?
Old March 11th, 2009, 04:10 PM
Overland90's Avatar
Overland90
Mirror Head simply drops/blows to 45 degrees (give or take).
arm to door hinge is solid.
Is their a tightening mechanism I'm missing...or just the design,
  • i.e. 6"x10" piece of plastic, rear weighted with glass being blown at 65 MPH on a round head is likely to tilt?
Old March 11th, 2009, 04:20 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
What do you want mirrors for, driving a 90 everything in front of you
3rd low and BOOT IT
Old March 11th, 2009, 04:23 PM
Overland90's Avatar
Overland90
I guess they are just dead weight
Old March 11th, 2009, 04:26 PM
hex (allen) fastener located on the bottom to tighten/loosen the swivel
Originally Posted by Overland90
Stupid problem...
Old March 11th, 2009, 04:35 PM
Overland90's Avatar
Overland90
Originally Posted by Ren Ching
hex fastener located on the bottom to tighten/loosen the swivel
that may explain something...I don't have one?
Will do some exploration on the assembly.
Old March 12th, 2009, 01:14 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
You have to have the hex head. That is how the assembly attaches to the arm.
Old March 12th, 2009, 01:43 PM
Overland90's Avatar
Overland90
After further exploration and Ren's feedback...it was located under a plastic cover under the arm. Problem solved.
Thanks again for the experts feedback on this forum.
