Defender engine comp fuse box installation - Defender Source
Old August 12th, 2015, 08:48 PM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
I found that my original 1994 NAS V8 engine compartment fuse box was literally dangling off the mount and does not have a cover. That combination and off roading have resulted in it being quite dirty, dusty and muddy and exposed to the elements.
I understand from a prior post / issue that one user had cleaned out his fuse box connections in the engine compartment and remedied an intermittent power loss issue (that I am also experiencing).
I don't have a cover and decided to order a new fuse box from RN (AMR1637) originally with the idea I would just use the cover. It then occurred to me that while I'm taking the original fuse box apart to clean it up and the connections, it may just make sense to replace the entire box (the kit comes with box, cover and long thick red cable).
Has anyone done this work before? Is there any trick to it? Is it a bad idea? Should I just clean the old box and connections and put on the new cover and leave as is?
Just seems like a good opportunity to get it all new.
My ultimate goal with these types of fixes is increased reliability (not just getting shiny new looking stuff).
Thanks in advance for the input.
Will
Old August 12th, 2015, 09:01 PM
I just had mine off today, but didn't go as far as moving the bottom cover to inspect the connections underneath. I would imagine they could be cleaned up, but all new would obviously be better. Mine doesn't have a cover either and I'd like to replace it as well - but that's a bit pricey for a cover.
Does that kit come with the other sides of the connectors?
Originally Posted by pendy
I'm here for the D's
Old August 12th, 2015, 09:20 PM
wmatos1001's Avatar
wmatos1001
William
The kit (for that price) looks to be the entire fuse box (top/cover and bottom) as well as the main wire (red). So that didn't sound too bad to me.
Old August 13th, 2015, 07:24 PM
Yes if the kit comes with the other sides of the connectors and you use it all I agree. But not for just the cover
defender, engine, installation
Fuse Box: Glass fuse --> Spade Fuse gonzanc Defender Technical Discussions 20 October 27th, 2016 11:54 PM
60amp accessory fuse B blowing in main fuse box owen Defender Technical Discussions 5 March 31st, 2013 09:18 AM
Cover fuse box for defender new in box and lev-o-gage sr jonathon For Sale - Parts 2 December 3rd, 2012 06:39 PM
Engine Fuse Box Cover thug1313 Wanted 3 April 20th, 2005 07:26 PM
pro comp tires jperakis Misc. Chit-Chat 7 December 1st, 2003 07:23 PM
