Defender duplicate key cutting? - Defender Source
Old September 7th, 2012, 01:02 PM
ssi19's Avatar
ssi19
scott
1995/D90
Hi All, i have a '95 D90 ST. Need to get a spare ignition cut and no one has been able to cut one successfully for me. Doesn't anyone know where to get one done? do I need to buy a special blank or something? I live in NY metro area. thanks in advance....
Old September 7th, 2012, 01:11 PM
I have had a key or two cut at Lowes... And they worked.
But, the LR Defender keys are no longer available... And when when you do find them they are about $50.
The 90/110 keys were hand cut with a tool that looks like a pair of pliers with a set of dials on them.
My kids love keys, especially the 90 keys and lost them before a local event, I called everyone, from the dealers to my buddy who is a LR market manager. They could not find a key for me, and they had to find someone who had the tool to cut it.
Old September 7th, 2012, 01:31 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
A key blank company "ILCO" makes the blanks (and there are many others). This key blank (grooving) has been used by many English car companys for several decades. As a 20+ year locksmith myself, the blanks are available at any reputable locksmith. The Ilco blank number is X157.
Download the keyblank manual http://www.kaba-ilco.com/key-systems...eferences.html
Then search under Rover as you will see the grooving on the X157 is repeated on several listings. The thing that changes is the keyhead, keyhead shape/material, or the key blank blade length beyond the shoulder stop. Generally, the lock is so sloppy that several of these keys will fit.
Old September 7th, 2012, 01:50 PM
Naplm00
Matthew
You can also buy blanks on ebay.co.uk pretty easy
Old September 7th, 2012, 02:20 PM
ssi19's Avatar
ssi19
scott
1995/D90
thanks everyone. a pleasure to hear from you all.
Old September 7th, 2012, 02:27 PM
LagunaDallasD90
Brady
1994 D90
I bought a couple of the below keys on eBay and had them cut yesterday at my local locksmith. They work perfectly (ignition) and took about a week to receive from the U.K.
http://www.ebay.com/itm/Land-Rover-B...#ht_4799wt_924
1994 D90 - #1689, 26K Original Miles
A Few Prissy Range Rovers (All Sold)
2009 Mercedes SL63 AMG
2013 Tesla Model S P85
Old September 7th, 2012, 03:29 PM
bossman429's Avatar
bossman429
Adrian
1988 90
I got a spare set made at LR for $30
cheaper than the blank themselves from Rovers North
Old September 7th, 2012, 03:44 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Ditto on the X157 or LF17 key. They can be found online in the US for about $5 each: http://mysecuritypro.com/ivecolf17keyblanks.aspx
Take them to a locksmith or an Ace Hardware. Ace did mine for free.
Semper Fi!
Old September 7th, 2012, 05:01 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
What about the door lock keys? The locksmith that did a couple of extra ignition keys for me couldn't do the doors. Is that a common blank or does that one have to come from the UK?
Old September 7th, 2012, 05:15 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Probably the X86 blank, as used on my '97 D90.
Old September 7th, 2012, 05:55 PM
My ST Door key worked in my SW, and about 4 other 90's...
Old September 7th, 2012, 07:05 PM
d90xjay's Avatar
d90xjay
J Phillips
1997 D90 SW
I have a spare set thats marked as Maserati that I received when I bought the 90.
Can the door locks be reworked or replaced to have the ignition key unlock them? Never liked having to carry two set of keys.
Old September 7th, 2012, 07:31 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
"Can the door locks be reworked or replaced to have the ignition key unlock them? Never liked having to carry two set of keys."
In 2007 and forward, Defenders come with a common key, ignition and front doors. Nothing before will work with the existing handles, pull or anti-burst. Pre 2007 doors, that have pull handles, can be changed out (the entire handle assembly) to accept the ignition key (re-keying of door cylinders required to match ign.).
The problem mainly arises from the fact that the ignition key is about 1/4" longer than the door key & subsequent door lock cylinder depth. Yes, the ignition key will go in the older Defenders, but not properly, and eventually you will twist or break off the key in the door.
Old September 7th, 2012, 10:02 PM
Really? My 1991 mod truck has the same key for everything.
Old September 7th, 2012, 10:07 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
http://www.ebay.co.uk/itm/set-2-Uncu...item3f1b23855c
Here's two for cheap?
You little rebel, I like you.
Old September 7th, 2012, 10:22 PM
Originally Posted by mgreenspan View Post
Strongly considering ordering this for my '94...
Old September 7th, 2012, 10:43 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
The military always seems to get the best. I don't know if "MOD" sets are readily available to public, would be great though.
Old September 7th, 2012, 11:14 PM
It says "1995-1998 Defender", any difference in the '95 vs '94 ignition?
Old September 7th, 2012, 11:37 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
These are the two keys for mine. The short one is the door key and the one I could not find. The other is the ignition. I thought I had read a long time ago that an older VW key might work
Old September 8th, 2012, 12:02 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Yep, X86 on the left (doors), X157 on the right (ignition)
wiki
94 NAS Defender 90-P.O.E.(Port of Entry) 1 of 65 made! on EBAY SeanD-90 Misc. Chit-Chat 29 May 27th, 2017 08:14 AM
defender 90 spare ignition key blanks d90boy Wanted 12 May 24th, 2011 04:38 PM
Dumb ignition/door key question, did search first Neo Defender Technical Discussions 15 May 30th, 2005 07:10 PM
110 roof, ignition key code, windshield frame, etc... martym Defender Technical Discussions 7 February 24th, 2005 01:45 PM
