Defender Doors Lock Question - Defender Source
Old June 10th, 2015, 09:47 AM
usadventureracing's Avatar
usadventureracing
Brett
110
I have an 83 110 and purchased all new door locks but the locks do not work, they just spin for the 4 doors.
For the rear door I also purchased a new mechanism and lock. The rear door lock works when the door is open but not when the door is shut.
1983 ROW D110
1970 Series III (Parting out)
Old June 10th, 2015, 09:06 PM
did you install the ball bearings in each lock?
Old June 10th, 2015, 09:22 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
If the lock just spins then the linkage may have fallen off. A tab is screwed onto the backside that holds the linkage. The rear door may just need to be adjusted. On the older trucks the catches are usually pretty worn and may need to be replaced.
Old June 11th, 2015, 07:19 AM
usadventureracing
Brett
110
Where is the ball bearing, should it have come with the new locks?
As for the rear door, that is what I was thinking, but before I start adjusting it I thought I would reach out.
1983 ROW D110
defender, door
door lock pull early style doors chasrover Wanted 1 June 19th, 2013 07:03 AM
Pressed doors ( TD5 / Puma ) lock barrel? leastonce Defender Technical Discussions 3 February 8th, 2013 02:27 PM
locks for second row doors, auto lock kit jayz Defender Technical Discussions 0 July 1st, 2012 04:58 PM
window lock for 2 piece 110 doors usadventureracing Wanted 0 March 23rd, 2011 05:30 PM
Overheating/ Diff Lock question icurnmedic Defender Technical Discussions 14 June 27th, 2006 06:06 PM
