Defender died, will start but dies after idles - Defender Source
Old May 16th, 2016, 07:02 PM
ymc226
Lawrence
1995 D90 SW NAS
Truck running fine. Will start so not a battery problem but won't keep on running unless the gas is continuously pressed. It starts repeatedly but always dies.
Old May 16th, 2016, 07:58 PM
carlosz's Avatar
carlosz
Carlos
so many variables its difficult to pinpoint.
air filterer fuel filter blockage, low fuel pressure, aic valve, timing plugs tune up air leaks, hoses, mae, oxygen sensors ...so much more...
Old May 16th, 2016, 10:29 PM
ron's Avatar
ron
Ron
1995 110 Beach Runner
Maf>>>>>>>>>>>
good luck with your search
Old May 17th, 2016, 01:11 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Agreed. $5 bucks says it's the MAF, throttle body, or stepper (IACV)
Sputters? Tach bobs a bit under 650 and then quits? Been there. Two different $8 cans of spray cleaners and 10 minutes and you should be golden. If not, $5 should buy you a pretty decent beer or two, to drink while you cross those three culprits off your list, and scratch your head again. ;-)
"Barry is correct!"
Old September 30th, 2016, 09:25 AM
ymc226
Lawrence
1995 D90 SW NAS
Thanks all, I had the throttle body cleaned when I initially posted in May and all was well until last night when it just sputtered and died as I pulled into my driveway. It started again with some difficulty and died again.
This time, I'll clean the throttle body again (had it done by the local mechanic) but I'll also look into the MAF. I know on the Porsche, the MAF can be cleaned but on a 95 NAS V8, can it be cleaned or is it better to replace?
Looking at the Rovers North, is the MAF in the Defender not a small, low cost part? For the 97 Defender it is around $1200.
Old September 30th, 2016, 09:41 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
This should do it I think. Should be PN ERR5198. $86 for aftermarket vs $1500 for OEM. I would try the aftermarket. Delivery from this supplier usually takes about 4 business days to east coast.
https://www.lrdirect.com/ERR5198-Air-Flow-Meter-3.9Efi/
Old September 30th, 2016, 10:15 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I had a problem like that. It turned out to be a vacuum leak. My brother had a special machine that pumped in smoke so you could see where the leak is. I resealed the upper plenum to the lower and it was fixed.
Old September 30th, 2016, 10:20 AM
lrna04's Avatar
lrna04
Michael
1994 D90
Check the code
Old September 30th, 2016, 10:25 AM
ymc226
Lawrence
1995 D90 SW NAS
Thanks Adam, just ordered the cheap Brit Part. Will clean the throttle this weekend and if still a problem, replace the MAF when it arrives. Is it plug and play or is there a reprogramming of the truck that needs to be done?
$86 vs $1200, sounds like I'm buying a Persian rug at full retail if I did buy the LR part.
Old September 30th, 2016, 10:43 AM
ymc226
Lawrence
1995 D90 SW NAS
It still sounds like the stepper motor (Idle Air Control Valve) Was that replaced. You can get an Astro van one at Vato Zone for $20 or so.
-Jeff
I'll get that too.
For all those that do their own wrenching, would changing the stepper motor and MAF sensor be easy in terms of technical difficulty and accessibility?
I did change out the plugs on my 911 which I considered a great accomplishment. If this is in the simple category, I'd like to tackle it myself.
Thanks Jeff: I found this at DiscoWeb:part #s are 25527077 for the ACDelco and 779-10003 for the GP Sorenson. $27 at Advance Auto. works for the 3.9 or 4.2 of course.
Old September 30th, 2016, 11:30 AM
Test things. Don't be a part swapper. The system is pretty simple and you can test each item to figure out what is wrong. Grab the workshop manual and go through the troubleshooting.
Old September 30th, 2016, 08:30 PM
ymc226
Lawrence
1995 D90 SW NAS
Thanks John.
I looked at the workshop manual on the CD that came with the truck when I bought it but it the V8 engine it describes is carburated so it is way out of date.
I just bought the NAS specific manual in binder form from Rovers North but will take a week or so to get here.
Is there an online version of the NAS specific Defender workshop manual that I can download from the internet as I'd like to get my truck back on the road sooner than later. I'm going to get the stepper motor tomorrow and clean up the throttle body as well and would like the appropriate work shop manual for instruction.
Old September 30th, 2016, 08:34 PM
Try the RRC Fuel Injection section: http://www.landroverweb.com/Pdf-file...-Injection.pdf I think it may be better to use. The NAS manuals are online somewhere as well, but I think they skip over a lot of the manual checks and assume you have a computer. If you are going to have this long time, then it would be worth getting a cable and setting up Rovergauge on a laptop. It makes life easier.
Old September 30th, 2016, 08:38 PM
Edit, wrong one...
Old September 30th, 2016, 09:50 PM
ymc226
Lawrence
1995 D90 SW NAS
Charles has some on his site. Untitled Document
As does Lav. https://www.seriesdefender.com/manuals.html
-Jeff
Thank you very much John and Jeff. I looked at these PDF's and they should work for me. Still want to get the NAS workshop manuals as they may be helpful.
Regards,
Lawrence
Old October 2nd, 2016, 03:24 PM
ymc226
Lawrence
1995 D90 SW NAS
Thanks all. I just changed the idle air control valve (from Pep Boys instead of LR thanks to Jeff) and air filter. Still waiting for the Britpart MAF from the UK but the truck idling is very smooth. Had it idle for 15 minutes and no shut off. Very, very happy. Can't wait to tell the wife as she was hinting the Defender was causing too much trouble and needed to be sold. That was my reason for trying DIY and not adding any unneeded cost to the situation.
What do you think? Is the air filter dirty enough to cause idling issues?
Old October 2nd, 2016, 03:54 PM
ymc226
Lawrence
1995 D90 SW NAS
Thank you Jeff, very happy.
Old October 15th, 2016, 09:34 AM
ymc226
Lawrence
1995 D90 SW NAS
Just for kicks, I changed out the old genuine LR MAF sensor for the new Britpart one that was recommended earlier in this thread as I already bought it.
Idle now is lower in the 500 range, much rougher and needs the gas to be pressed to keep it from dying and the CEL is now on. Does the new MAF need to "learn" or is this a defective one? Later today, I'll reinstall the LR MAF.
Old October 15th, 2016, 08:34 PM
I had this issue. Turned out I had 2 bad IACV's (primary and spare)
Replaced it with a new one and it's all good...
Also check your distributor rotor.. recently seen one that had a hair line fracture allowing start then it died, and another at MAR which did the same thing (no start this time )
Check it even if you just replaced it, they are all crap now days (even new ones)
------ Follow up post added October 15th, 2016 05:36 PM ------
The 14cux has no learning capacity...
I'd return it, imho
95' D90 - daily driver..
Old October 17th, 2016, 01:29 PM
ymc226
Lawrence
1995 D90 SW NAS
I'd return it, imho
Thanks. Prior to replacing the MAF sensor, the idle issue cropped up again. Just got another IACV and will replace it as well. This time I got the AC Delco part. Prior part was some no name brand from Pep Boys.
defender, idle, start
now idles high?? kevincdoyle Defender Technical Discussions 14 September 21st, 2015 09:52 PM
200tdi Replaced nozzles idles rough Tribe Defender Technical Discussions 12 August 27th, 2015 09:48 AM
Won't start after after torrential downpour?! jijalicious Defender Technical Discussions 51 November 10th, 2011 12:17 PM
Jaguar Land Rover CEO Polites dies at 60 after illness 94Rover Misc. Chit-Chat 5 April 21st, 2008 09:24 AM
Dies after start benh Defender Technical Discussions 2 May 20th, 2004 03:04 AM
