Defender died, will start but dies after idles - Page 2 - Defender Source
Join the Defender Source Community Today
Old October 2nd, 2016, 03:54 PM
ymc226
Lawrence
1995 D90 SW NAS
Thank you Jeff, very happy.
Old October 15th, 2016, 09:34 AM
ymc226
Lawrence
1995 D90 SW NAS
Just for kicks, I changed out the old genuine LR MAF sensor for the new Britpart one that was recommended earlier in this thread as I already bought it.
Idle now is lower in the 500 range, much rougher and needs the gas to be pressed to keep it from dying and the CEL is now on. Does the new MAF need to "learn" or is this a defective one? Later today, I'll reinstall the LR MAF.
Old October 15th, 2016, 08:34 PM
I had this issue. Turned out I had 2 bad IACV's (primary and spare)
Replaced it with a new one and it's all good...
Also check your distributor rotor.. recently seen one that had a hair line fracture allowing start then it died, and another at MAR which did the same thing (no start this time )
Check it even if you just replaced it, they are all crap now days (even new ones)
------ Follow up post added October 15th, 2016 05:36 PM ------
The 14cux has no learning capacity...
I'd return it, imho
95' D90 - daily driver..
Old October 17th, 2016, 01:29 PM
ymc226
Lawrence
1995 D90 SW NAS
I'd return it, imho
Thanks. Prior to replacing the MAF sensor, the idle issue cropped up again. Just got another IACV and will replace it as well. This time I got the AC Delco part. Prior part was some no name brand from Pep Boys.
defender, idle, start
now idles high?? kevincdoyle Defender Technical Discussions 14 September 21st, 2015 09:52 PM
200tdi Replaced nozzles idles rough Tribe Defender Technical Discussions 12 August 27th, 2015 09:48 AM
Won't start after after torrential downpour?! jijalicious Defender Technical Discussions 51 November 10th, 2011 12:17 PM
Jaguar Land Rover CEO Polites dies at 60 after illness 94Rover Misc. Chit-Chat 5 April 21st, 2008 09:24 AM
Dies after start benh Defender Technical Discussions 2 May 20th, 2004 03:04 AM
