Defender coolant - Defender Source
Old January 7th, 2016, 07:21 PM
Anschluss
T B
white 1997 Defender 90 NAS
Defender coolant
Ok. Trying to be efficient i had the local LR dealership flush my rad before winter storage. I had green coolant...they flushed and replaced with a pink or orange coloured coolant. It's their LR brand. Extended life blah blah blah.
I read that this is fine for the aluminum engine but not good for Brass/copper rads. Well now. Isn't a 97 defender rad made of those very items? Original rads aren't aluminum are they? Do i need to flush this out for green coolant in thr spring? Thanks for your thoughts people.
Old January 7th, 2016, 08:28 PM
green is best
Old January 7th, 2016, 09:29 PM
87 D110 (Ruby)
Green = Good
Old January 7th, 2016, 10:52 PM
Green. The cheap stuff. These trucks love it.
Old January 7th, 2016, 10:55 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I use Zerex G-05.
Old January 9th, 2016, 02:45 PM
olsin77's Avatar
olsin77
Olsin Petro
1999/Defender 110
Green is the old type.
Pink is less corrosive.
Old January 9th, 2016, 02:50 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
There are several threads on this. Don't use Pink. Use Green.
Old January 17th, 2016, 09:01 AM
Anschluss
T B
Thanks for everybody's input. OK in the spring...time for another flush.
Old January 17th, 2016, 09:41 AM
For what it's worth, it can be difficult to bleed the system...I ended up jacking up the passenger side of the vehicle as high as I could to get it to "burp". That was about the only thing that would get rid of the air bubble I apparently had in the 3.9 since it kept creeping up in temp. After that I was good to go.
coolant, defender
Coolant Type for Disco/Defender 200tdi pdsftw Defender Technical Discussions 3 October 18th, 2015 01:52 PM
14 CUX Defender Coolant Temperature Sending Unit Jymmiejamz Wanted 20 May 14th, 2014 03:07 PM
water coolant reservoir discovery/defender Shop On Broward For Sale - Parts 1 January 8th, 2013 09:03 AM
Oil coolant Lines*revisited* for '97 Defender Frankie Carbone Misc. Chit-Chat 10 December 2nd, 2007 04:23 PM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
