Defender AC Conversion - Defender Source
Old May 17th, 2015, 07:48 PM
NAS Addict's Avatar
NAS Addict
Jeff
95 D90 ST #2617
Greeting,
I have a 95 NAS that did not come with factory AC. Is there anyone out there that has added an entire AC system to their D90? Any lessons learned to shops that can be recommended. I have seen the kit on Roversnorth for $3400. Anybody used this?
Thanks for the advice!
Old May 17th, 2015, 07:56 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Subscribed. Good luck. I'd like to hear about this too.
AFAIK, I think that the RN kit is the only option, but it's a lot nicer than the '95 stock unit. I would think that if you're relatively handy, you'd be able to tackle it yourself. It is a complete kit. How long are your summers in CO?
Old May 17th, 2015, 08:00 PM
NAS Addict's Avatar
NAS Addict
Jeff
95 D90 ST #2617
We have a few good months of summer here. Though we rarely break 90, the intensity of the sun makes 50 degree days shorts weather!
Old May 17th, 2015, 08:31 PM
Subscribed - in Florida so (1) very interested in this thread and (2) laughing about the intensity of the sun in Colorado
Old May 17th, 2015, 09:22 PM
rovertrader's Avatar
rovertrader
Dale
I have a take out unit from my '95 if interested, half price of new, $1500
Old May 17th, 2015, 09:35 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
No reason for a sophisticated custom install...
ID:	121023   Click image for larger version
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old May 17th, 2015, 09:49 PM
NAS Addict's Avatar
NAS Addict
Jeff
95 D90 ST #2617
PM sent
Old May 18th, 2015, 06:42 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
It is an easy install. Most of the kits are plug and play. If you pry off your fuse box cover look for a brown connector pigtail that has a cover on it, nothing going to it. Sometimes it is attached to the fuse box metal plate on the inside area. If you have this then you should be able to just run all of the new equipment and just plug the wire of the kit into this. You will need to gt a shop or if you have one vacuum the lines before you install the freon.
Old May 18th, 2015, 11:03 AM
Cool, a pickup with an APU.
Old May 18th, 2015, 12:15 PM
chuckc4
chuck b
Registered User
I have been eying the RN kit myself. Having had a '94 with a factory installed AC, the RN kit looks like it is a much better solution.
Old January 19th, 2016, 11:44 AM
aquatiger's Avatar
aquatiger
S
none
Did you ever end up installing an AC kit? I am considering the same.
Old January 19th, 2016, 01:27 PM
BlackField's Avatar
BlackField
Oscar
D110
I made a kit from mostly scratch, I could have done a better design for flow on some of the couplings but it works. I'm considering scanning my parts and re doing them in ABS with smoother transitions and less bottle necks.
After it was all said and done I don't think $3400 is too far out there, especially for plug and play.
ac, conversion, defender
Defender auto conversion parts Grade A pendy For Sale - Parts 8 February 18th, 2014 01:35 PM
LHD Conversion Kit for Defender Ren Ching For Sale - Parts 12 September 25th, 2013 03:37 PM
Defender Auto Conversion Rugbier For Sale - Parts 29 January 28th, 2013 10:09 PM
1994 Defender 90 #342 Soft Top with Full Station Wagon Conversion BadMonkey For Sale - Vehicles 2 August 14th, 2012 03:21 PM
Wanted- Defender or coil spring 110/109 for Series 109 conversion Rovermn Wanted 1 August 4th, 2008 06:04 AM
