Defender 90 Won't Start - Defender Source
Old March 5th, 2016, 05:56 PM
ruggedalaskaman's Avatar
ruggedalaskaman
Frank
1995 NAS D-90 #375
I have a 95 NAS 90 with the stock 3.9. ECR went through the engine before I moved back to Alaska a few months ago to include installing a new fuel pump. The vehicle has started flawlessly on the first or second crank every time until Thursday when I wanted to use it. I can hear the fuel pump pressurize when I hit the key. The vehicle cranks strong, but doesn't fire. Any thoughts?
Frank
Old March 5th, 2016, 07:48 PM
fruitpunch
Marc Brouwer
66 IIa 88 Perkins powered
check both relays, fuel / ignition next to ECU. they are identical swap them over... if you don't hear pump you know the other one was bad.
Old March 5th, 2016, 08:50 PM
ruggedalaskaman
Frank
1995 NAS D-90 #375
Thanks for the reply. Do the relays just fail like that without warning?
Old March 5th, 2016, 09:04 PM
xjahx's Avatar
xjahx
JAH
'93 NAS 110, '94 NAS ST, '85 90 PU
Yes.
Old March 5th, 2016, 09:32 PM
ruggedalaskaman
Frank
1995 NAS D-90 #375
Old March 6th, 2016, 08:14 PM
ruggedalaskaman
Frank
1995 NAS D-90 #375
So I finally have time to check the relays today and decide to try and start it one more time. As soon as I touch the key it fires up and runs perfectly. Any thoughts of what would cause this condition?
Old March 6th, 2016, 08:17 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
I had some issues with intermittent starting before my ignition switch packed it in, then it would not start at all. Something else to check. Good luck.
Angus
Moisture
Old March 6th, 2016, 09:18 PM
doktorno
Chris deZ.
1995 Defender SW
My '95 is at SWR Automotive with the same problem. Never an issue in TX, but this winter in NM a cold start issue showed up. I suspect it was over fueling at startup, causing the engine to flood. It is my understanding that this overfueling at startup intended to warm the catalytic converters was a problem that was corrected on later ECUs, but I am just internet smart on these vehicles.
90, defender, defender 90, start
94 Defender won't start worsethenu Defender Technical Discussions 36 August 20th, 2014 04:51 PM
Won't crank, Won't start. revor Misc. Chit-Chat 4 September 16th, 2010 09:48 PM
94 Defender 90 cranks but won't start Charles LF Defender Technical Discussions 6 September 9th, 2009 02:43 PM
Defender won't Start DJ Menasco Defender Technical Discussions 21 January 29th, 2007 11:04 AM
Another "My Defender won't start" question MiniGuy Defender Technical Discussions 4 December 28th, 2005 12:51 PM
